586,061 active members*
4,574 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Master cam swarf 4axis finishing inconsistency
Results 1 to 6 of 6
    Mar 2022
    I am trying to manufacture a rotary die cutter i am not sure if anyone is familier with this application but anyone willing to help can google it and attached is a picture of the work piece
    My main problem is finishing the blade of the cutting edge of the work piece its 45degrees angle perpendicular from the z axis and the tip width is 0.04mm the problem is that i try to finish this blade using a 4axis machine with a ball nose tool and the end result is that i get inconsistent tip width varying from 0.0mm to 0.1mm while the part itself its 0.04mm.
    Any suggestions??
    Attached Thumbnails Attached Thumbnails Screenshot_20220308-220636_Samsung Internet.jpg
    Apr 2003
    3578
    Re: Master cam swarf 4axis finishing inconsistency
    Look at using RollDie option in the Chooks. or application based on what version you are running.
    Cadcam
    Try making sheets and extend the edges of the sheets. It should tighten up the scallop issue's
    I would try the sheets op. first also. Sounds like you just don't have enough machining suface. Using sheets will fix that issue.
    Apr 2003
    3578
    Quote Originally Posted by RickPhillips View Post
    Are you saying to make Sheet solid extensions or do you mean Surfaces as extension run off surfaces?
    Cadcam
    Dec 2008
    3109
    Quote Originally Posted by Ragyw View Post
    Any suggestions??
    Looks like a "nappy" (or diaper) cutter
    If you keep tool centreline on rotary centreline...ie 4 axis toolpath...
    Your issue would be related to the vertical linework cut- point on the ballnose is different to the horizontal cut-point. ( a very small arc error)
    Rotary cutters, brings back old memories
    We used PEPS, later switched to Mastercam (used an ANCA control g-gode to turn an XY path onto a rotary radius).
    We could not rectify that 4 axis error, had to be finished off manually under microscope etc.)
    5 axis paths we too new to the company and I had left before any attempts.
  1. 4axis rhinocam parallel finishing act weird
    By alextech in forum Rhinocam
    Last Post: 06-05-2017, 01:43 PM
  2. Feature-Cam to Master Cam
    By BGORDON in forum Uncategorised CAM Discussion
    Last Post: 08-22-2013, 02:27 PM
  3. Replies: 7
    Last Post: 02-04-2011, 03:21 PM
  4. Master-Cam
    By johnsguns1 in forum Mastercam
    Last Post: 04-08-2008, 09:29 PM
  5. master cam x
    By frankg521 in forum Machines running Mach Software
    Last Post: 10-31-2007, 01:10 PM
