586,728 active members*
3,488 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Fa10 mit. Wire EDM. Alarm
    Can anyone give a consult. I just bought a wire EDM machine everything was fine till we moved the machine to another location now the machine give U795 Alarm Axis over run.
    The manual Suggest to check all the limit switches, and to check for broken cables. I opened all of the covers and checked all of that and 2+3 X axis limit switches 2+3 Y axis limit switches and the 2+3 Z axis micro limit switches. Checked for broken cables. There are no broken cables.
    Dec 2006
    585
    Re: Fa10 mit. Wire EDM. Alarm
    Is the machine phased correctly for the incoming voltage?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Quote Originally Posted by meckardt55 View Post
    By. phased correctly you mean if the R T S phases are in order. Then Yes, i connected the machine by the manual instructions.
  1. Sodick AG600L Wire EDM - EDM wire rewinds to spool after cut at end of program.
    By nlancaster in forum EDM Discussion General Topics
    Last Post: 04-19-2022, 08:02 PM
  2. NEED POST BOBCAD V28 FOR MITSUBISHI FA10 OR FX10 WIRE
    By diemaker89460 in forum BobCad Post Processors
    Last Post: 06-25-2016, 06:57 PM
  3. FA10 WIRE EDM
    By CLATHAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-29-2011, 07:49 PM
  4. Charmilles Wire EDM Alarm E01 P02?
    By henriusa in forum EDM Discussion General Topics
    Last Post: 06-12-2010, 05:30 PM
  5. edm sinker mit. ae series
    By drill in forum DNC Problems and Solutions
    Last Post: 06-10-2005, 08:37 PM
