586,390 active members*
2,916 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Moves half as far after spindle change
Results 1 to 3 of 3
    Mar 2022
    Question Moves half as far after spindle change
    Good day,
    I bought my first CNC machine a while ago, the FoxAlien CNC Router 3018-SE V2. In the last few days I have made some small upgrades, including I have replaced the spindle for the X-axis.
    However, I probably bought the wrong one. The CNC machine now moves only half as far as it should in the X direction, if before it moved 10 cm in the X direction it now moves only half as far with the same G-code. (The stepper motor rotates as before )
    Now my question:
    Can I solve this by a setting in the software (Currently using Candle, but am also open to other software) , or otherwise solve without having to buy a new spindle?
    With kind regards
    Fabian
    Dec 2013
    5717
    Re: Moves half as far after spindle change
    I'm pretty sure changing the spindle would not have any effect on the X travel distance. Most likely you need to change the X calibration in the software.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    1228
    Absolutely correct if using the terminology we commonly associate with machines,but curiously the OP describes the "spindle" for the X axis.Does he mean stepper? I suspect so and that does indeed point to a calibration issue.
  1. only half spindle speed
    By bulburn in forum Okuma
    Last Post: 05-28-2021, 01:32 PM
  2. Replies: 16
    Last Post: 01-28-2021, 06:14 AM
  3. Z- 0 moves before tool change...
    By airbrush in forum BobCad-Cam
    Last Post: 06-17-2016, 06:52 PM
  4. Goto G30 - moves all 3 axes at once. Dangerous for a tool change.
    By brianbonedoc in forum Tormach PathPilot™
    Last Post: 08-18-2015, 03:36 AM
