586,094 active members*
3,943 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Facing not symmetrical...
    Mar 2021
    6
    I'm trying to face my surface with a new (huge) cutter, and it keeps overshooting my soft limits on the machine. When I select an inch or 2 of Stock Offset it's not symmetrical. Then I noticed that it's never symmetrical! Reducing the size of the design has sort of worked... I would like to understand this behavior in Fusion.
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails 2022-03-13_17h00_37.jpg   2022-03-13_17h06_51.png
    Mar 2021
    6
    Re: Facing not symmetrical...
    I like to live dangerously...
    Mar 2008
    683
    Not quite sure what you mean. But Fusion will drive the edge of the cutter to the overlap. Sold let's say you have a 3" fly cutter and tell it to cut one inch past the stock. It will drive the cutter on inch past so there will still be 2 inches on the part making the toolpath appear to be non symmetrical even though it is doing what you told it.
  1. Weird issue with z axis non-symmetrical movement
    By Xnaron in forum Mach Software (ArtSoft software)
    Last Post: 06-24-2020, 07:58 PM
  2. V22 Facing ?'s
    By bink in forum BobCad-Cam
    Last Post: 02-16-2009, 12:22 AM
  3. cylinder facing
    By pp-TG in forum MetalWork Discussion
    Last Post: 01-30-2009, 03:53 PM
  4. Facing operation
    By mikeh78 in forum BobCad-Cam
    Last Post: 07-14-2008, 11:08 PM
  5. Facing
    By impact in forum MetalWork Discussion
    Last Post: 02-23-2006, 03:24 AM
