586,389 active members*
3,058 visitors online*
Thread: Tool sensor
    Tool sensor
    I need to figure out how to hook my tool sensor up. I have a sheet that said input5 pin. But don't see that on my board.
    Jun 2021
    105
    Re: Tool sensor
    To get the best support from forum members, I am sure they will need more details from you such as the type of controller board and sensor you are using. I am sure you will have a solution soon after that.
    Re: Tool sensor
    I have a CNC USB Controller MK3/4 from Planet Cnc. The sensor is the one that came with machine. Round button with a wire to button and a wire with alligator clamp. Hope this helps
    Jan 2007
    626
    Re: Tool sensor
    I'd also suggest that you, when time permits, terminate your wiring with good quality and correct sized crimp lugs.
    A single loose strand can cause no end of problems
    Jan 2018
    1516
    Quote Originally Posted by Sdwooster View Post
    That's a dodgy looking black wire connected to board below the filter.
  1. Tool sensor
    By MAHNKEN in forum UCCNC Control Software
    Last Post: 10-25-2021, 02:27 PM
  2. Replies: 1
    Last Post: 01-01-2020, 12:15 AM
  3. tool legth sensor
    By eddy stoop in forum CNC Tooling
    Last Post: 11-01-2012, 11:46 AM
