586,116 active members*
3,334 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > USB breakout board and touch plate problem
    Nov 2010
    Good day everyone,
    I have lingered in the back ground for a few years now dreaming of the day I could own my own CNC Router. I finally got one. Bought a Bulkman 3D, I have it up and running with some help from a friend.
    Today I was trying to hook up a touch plate, my two wires that go to the touch plate work , as the z is coming down I touch the two wires and it works with the script I installed. Great I thought.
    The problem starts when I touch the router collet it sparks, then nothing happens. I have a XC E-cut 4 axis USB brake out board running Mach3. It’s running 24V. Has anyone had this problem before.
    Note: Limit switch’s work, also when I touch the collet the limit switch lights up in the Mach 3 diagnosis. Otherwise machine works great. Any help will be appreciated.
    Thanks.
    Apr 2013
    1899
    Re: USB breakout board and touch plate problem
    Not easy to help from that description... Unknown CNC, unknown electronics, unknown wiring... a lot of unknown but important facts. When you say "it sparks" do you mean literally? In that case you have a serious electrical issue. Also, you have two wires. Does it sparks regardless which wire you touch the collet with? Probably you have a grounding issue, but it is impossible to say from this post. I think you should find someone near you with some (the more the better) electrical knowledge who can measure and fix your problems.
    Mar 2022
    However, remember the maximum current from a USB port is 500mA. There are two types of common breakout boards for this chip: One with only the charger chip ...
    https://esurveys.onl/tellthebellcanada/
  1. CNC USB MACH3 100Khz Breakout Board problem
    By batadjero in forum Controller Cards
    Last Post: 12-27-2018, 10:42 AM
  2. 6040 Touch Probe Connection Place on this Breakout Board?
    By mikejohn37 in forum CNC Machine Related Electronics
    Last Post: 07-18-2018, 12:19 AM
  3. Problems with Touch plate connecting to Breakout board
    By tvheadclothing in forum Stepper Motors / Drives
    Last Post: 01-24-2015, 04:43 AM
  4. USB BREAKOUT BOARD
    By smarbaga in forum Open Source Controller Boards
    Last Post: 04-14-2009, 01:33 PM
  5. what USB Breakout Board to by ??
    By dbss in forum CNC Machine Related Electronics
    Last Post: 01-19-2008, 02:54 PM
