587,008 active members*
3,547 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Journeyman 250 X axis noise
    Nov 2004
    24
    Just purchased this mill and have no experience with Tree or Dynapath 40m control. I do have the manuals which are helpful and I’m kind of learning things as I go. I’ve found that when I jog the X axis in fast or rapid mode I’m getting a rather annoying high pitched squeal. I’m concerned it may be due to a dry ball nut. This machine of course has the automatic lube system but I don’t know of any way to confirm if the nut is receiving lube? Any ideas what could be causing the noise and what I can check? I thought it may also be the screw end bearings but haven’t had time to investigate.
    The spindle likewise is making a rattle noise occasionally when decelerating. I’m guessing bearings are likely the culprit there.
    Thanks for any insight offered!
    Dan
    Aug 2009
    1573
    Re: Journeyman 250 X axis noise
    ...turn up the Radio vs the noise??
    Dynapath 40--is good running?
    Nov 2004
    24
    great idea!
    It’s running yes, not sure how well yet as I’ve only done simple MDI commands. I bought this mill knowing it would need some TLC but the fact that it’s fault free to begin with is a bonus.
    Nov 2004
    24
    Found the source of the squeak / screech in the X axis. I removed the table shroud for cleaning and inspection and the noise is gone. It must have a non factory bend in it somewhere. TG it wasn’t the screw and bearings.
  1. Tree Journeyman 250 Dynapath 250
    By phatfred8 in forum Tree
    Last Post: 12-20-2012, 06:54 PM
  2. Tree 250 Journeyman
    By J. R. Williams in forum Tree
    Last Post: 10-26-2011, 04:36 AM
  3. Tree Journeyman 250 or 325
    By MechWerks in forum Tree
    Last Post: 04-01-2008, 05:26 PM
  4. (NEED HELP) TREE Journeyman 250
    By tspowell in forum Tree
    Last Post: 03-31-2008, 03:11 PM
  5. Tree Journeyman 250 CNC
    By tommy tr in forum MetalWork Discussion
    Last Post: 04-01-2007, 08:55 PM
