586,111 active members*
3,522 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree journeyman Fault
Results 1 to 10 of 10
    Nov 2004
    24
    Okay, I'm still shaking out this new to me 250. Occasionally I'm getting the following fault message. "MTB Fault Message Number 20". It doesn't stop the machine or anything but its quite annoying. Has anyone seen this or can point me in the right direction on eliminating the fault that is throwing this error? It doesn't appear in the operation manual that I have for this machine.
    Thank you,
    Dan
    Oct 2006
    60
    Re: Tree journeyman Fault
    From the ladder: MTB FAULT MESSAGE 20: 20 LUBRICATION TIMEOUT
    The machine is not satisfying (closing) the lubrication pressure switches within the allotted time, or if they are closing they are staying closed too long.
    The switches should close when pressure is built, then maintain a closed state for 15 seconds or so, then re-open.
    Manually pump the lube pump a bunch of times, make sure the lube filters are clean, make sure the switches function.
    [email protected]
    Nov 2004
    24
    Quote Originally Posted by zpsbob View Post
    [email protected]
    Thank you for responding Bob. This is going to sound nubish but where are the filters? I know next to nothing about the lube system. I do here it kick on once in a while. I also placed a mark on the reservoir tank to see if the oil level was dropping.
    Just took the cover off and don’t see a way to manually operate the pump?
    It’s a Vogel model 123 135 300. I found the manifold and pressure switch. I’m not sure how to clean the filters since I don’t know where to find them or how to operate the pump manually.
    Thanks again!
    Oct 2006
    60
    There should be a filter in line after the lube pump and a filter screen on the oil intake inside the oil tank itself.
    There are two versions of the Vogel lube system used on these machines. One version has a switch on the pump to manually run it, the other version I think you manually pump it by putting the machine in e-stop and then pressing the reset button.
    There may be two pressure switches, one on the manifold on the saddle, and maybe one on a second manifold in the headstock.
    [email protected]
    Nov 2004
    24
    Okay, I'll keep at it. Here's a pic of the unit I have with the cover removed.
    Attachment 477330
    Nov 2004
    24
    I don't see any inline filter after the line leaving the pump. There are at least 3 junction blocks. The Machine manual shows a "Filter Pipe" inside of the manifold and a couple of the junction blocks. I'll see if I can take one apart and see what that is about.
    Okay the filter pipe is inside the manifold. It’s like an aquarium bubble rock. I cleaned it real good in solvent and replaced it. Don’t think it was clogged as it looked pretty clean. I lost quite a bit of lube out of the manifold when I removed it. So I know I’m getting way lube at least part of the time.
    Nov 2004
    24
    Cycled the machine multiple times over an hour or so, still no joy with ladder 20 fault. I checked the wiring diagram and see the Vogel power comes through FU8 and then a relay, K10. Going to check the fuse in the morning to make sure it’s good. I did try and measure voltage to the relay on the pump. Nothing like the 230v the diagram shows. Does the relay only energize when the pump pressure switch closes and then reopens from pressure bleed?
    Nov 2004
    24
    Okay - my issue with the Vogel lube pump is resolved. I tracked down the controlling relay (KA-10), cleaned, reseated, and the pump kicked on at first power up. I cycled power a few times to build up pressure in the system and have noticed an 1/8” drop in reservoir oil level.
    I’ll continue to monitor to ensure the issue is fixed. A big thanks to ZOSBob for the assist!
    Oct 2006
    60
    Sweet! glad you got it going. Be careful with those Vogel lube pumps. They are very expensive!
    [email protected]
    Nov 2004
    24
    [email protected]
    Boy you ain’t kidding! I had contacted devco to see about a manual for this pump or similar. He told me it’s obsolete and no manual available but he’d quote me a new one. Wouldn’t give me a manual but was sure ready to sell me one at $1600 US. Gulp, thanks but no thanks.
  1. New to me Tree Journeyman 425
    By slodat in forum Tree
    Last Post: 04-06-2021, 02:08 AM
  2. tree 325 journeyman
    By cncrouter in forum Tree
    Last Post: 01-22-2013, 02:45 PM
  3. Tree 250 Journeyman
    By J. R. Williams in forum Tree
    Last Post: 10-26-2011, 04:36 AM
  4. (NEED HELP) TREE Journeyman 250
    By tspowell in forum Tree
    Last Post: 03-31-2008, 03:11 PM
  5. Tree Journeyman 200r
    By Steve L. in forum Tree
    Last Post: 01-20-2008, 02:37 PM
