Re: 4TH axis powered by delta servodrive.
Originally Posted by
hernault
Hello.
I would create a 4th axis on my vm25 then i buy delta servodrive and motor. I buy delta material because it was much less expensive than yaskawa. My motor is able to run till 3000r/min but if a put a speed over 1500r/min centurion turn on excess error. Something strange is if i turn in one direction there's no pb but in the other direction a have an excess error. I tryed to put in parameters yaskawa drives on NO, thinking my servomotors yaskawa are limited to 1500r/m but nothing change, always : excess error.
Does someone had the same problem?
Is there a solution?
Thank you for your help.
Hernault.
Could it be over soft limit of the axis? is there any alarm code on the driver?
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
