586,553 active members*
3,471 visitors online*
Results 1 to 5 of 5
    Mar 2022
    Freelance or PT Mastercam programmer needed !!!
    Ideally a person within a reasonable distance for a one time meeting would be best, but we are willing to look at all freelance programmers and their business models from all over. Mastercam but if you use a different software and it ends up coming out the same as our desired results, thats totally fine.
    This is for programming 4 axis Makinos...to be honest, to the right person, I bet this programming would be pretty easy, however, due to the lack of memory in our machines, we currently use very few lines with sub routines grabbing them from the server...
    We would still need to keep things this way.
    The type of part to be programmed, will always be the same, just different variables...
    I may not check back here for messages always, so feel free to email me
    [email protected]
    Jim
    Dec 2003
    1230
    Re: Freelance or PT Mastercam programmer needed !!!
    Don't you think it might be useful to indicate which country you are based in?It does help if the programmer is in roughly the same time zone......
    Mar 2022
    Yes, so sorry...Windsor, Ontario. EST
    Oct 2021
    10
    Quote Originally Posted by jjewell View Post
    I have emailed you and look forward to your reply
    hello i am chinese
    Nihao (hello) I have been engaged in CNC programming for ten years in China. I am proficient in MASTERCAM
    The software used in the work is POWERMILL nx hypermill vecut, which can make a perfect cutting path. The same four axes and five axes can be applied remotely if necessary
    Mailbox [email protected]
    thank you
  1. Looking for freelance Gibbscam Programmer
    By Bangerla in forum Employment Opportunity
    Last Post: 06-08-2022, 01:49 PM
  2. Mastercam MIll Freelance Programmer
    By aussiepaul in forum Employment Opportunity
    Last Post: 01-14-2017, 07:44 AM
  3. Mastercam Programmer Needed
    By Zeke13 in forum Employment Opportunity
    Last Post: 09-09-2015, 02:23 PM
  4. Looking for a freelance machine controller programmer
    By bulunmaz in forum Employment Opportunity
    Last Post: 01-22-2012, 10:55 AM
  5. Freelance Programmer
    By elmor fudd in forum Employment Opportunity
    Last Post: 01-27-2009, 08:54 PM
