586,523 active members*
3,444 visitors online*
IndustryArena Forum > CAM Software > Mastercam > entry motion for cnc wood router
    Dec 2009
    42
    using mastercam x6 thermwood cnc wood router
    i realize mastercam x6 is very old. however, we only cut wood all the way through. no need to upgrade as it works perfectly for our need.
    would like to get some help on a entry motion cutting 2 sheets of 3/4 plywood/osb all the way through.
    when using a 3/8 3 flute carbide bit, with a plunge cut, the bit usually snaps. a 1/2 inch bit works good with plunge cut.
    using a 45 degree ramp with the 3/8 bit works, however, when cutting a stright line i do not want to have to go back and clean out the ramp area
    after a long cut.
    what i need to do is ramp in, backup to take out the ramp area, and then continue the straight cut.
    enclosed is a example
    thanks for the help
    Apr 2003
    3578
    Re: entry motion for cnc wood router
    Quote Originally Posted by thereclinerman View Post
    after a long cut.
    thanks for the help
    This should give you what you want. if you lower the depth cuts you get more.
    Cadcam
    Dec 2009
    42
    thank your for answering.
    sorry i did not explain myself fully. what i meant to explain was that once it had ramped to depth, the bit would reverse then and take out the ramp and then reverse and continue on the cut.
    so it would basicly take out the ramp area in the first couple of inches after ramping to depth.
    the reason for this is i am using a down shear bit and the cut wood/swarf stays in the cut to help prevent movement on common line cutting.
    thanks
  1. Replies: 0
    Last Post: 12-24-2019, 02:47 AM
  2. 1630 3 axis CNC Router Wood Machinery for Solid Wood Boards
    By BlueElephantCNC in forum News Announcements
    Last Post: 11-13-2019, 09:30 AM
  3. Small CNC Wood Router VS Large CNC Wood Router
    By omnicnc in forum News Announcements
    Last Post: 03-16-2013, 06:25 AM
  4. Entry-level CNC router
    By asifjahmed in forum Commercial CNC Wood Routers
    Last Post: 11-09-2012, 07:41 PM
  5. Need to buy a entry level CNC Router like CNC 3040\3020
    By zegeli in forum CNC Wood Router Project Log
    Last Post: 09-04-2012, 06:37 PM
