587,047 active members*
2,695 visitors online*
    Oct 2005
    1145
    AUX function buttons (;-)
    IF you have thought about having AUX buttons to do functions check out this USB emulator board. IT emulates a std keyboard so PP thinks it is a keyboard. The buttons you assign as a hotkey so pressing the button is exactly like clicking on the screen with the mouse. REMEMBER GameBoys push a mouse but REAL chipslingers press buttons. (;-) I do hope you have a sense of humor (;-)
    RED = stop
    GREEN = CycleStart
    Yellow = Feedhold
    Blue = coolant
    White = spindle
    JUST like the big boys.
    https://www.ultimarc.com/control-int...i-pacs/i-pac2/
    AND these fancy chrome colored buttons at the bottom of the page.
    https://www.ultimarc.com/arcade/buttons/
    There are even wiring harnesses so it could be very easy to wire up. Also it does NOT use keymatrix connections and the associated problem with that.
    IT gets better every day around here (;-)
    Just a thought , (;-) TP
    Nov 2012
    591
    Re: AUX function buttons (;-)
    I built something very similar out of a Teensy microcontroller a few years back. My Blue does air blast (through an external solenoid) but other than that, very similar mapping!
    (Of course I made the case and whatnot on the actual mill.)
    Nice to see someone did the software work so someone who's not into that can just have some cake!
    Oct 2005
    1145
    We are also testing using keyboard macros to do functions like alt_enter to enter MDI mode then o<test_sub> call to run the test sub. This will automate some functions down to a single button push. NOW that is the machine working for ME.
    (;-) TP
  1. Aux Keypad
    By vmax549 in forum Tormach PathPilot™
    Last Post: 02-18-2022, 08:56 PM
  2. Current Step jog function buttons
    By Steler in forum PlanetCNC
    Last Post: 04-08-2021, 06:42 PM
  3. Coolant to aux port but no power to aux. ports, need help!
    By ballistic42 in forum Benchtop Machines
    Last Post: 02-15-2015, 08:08 AM
  4. Programing AUX buttons
    By George C in forum Centroid CNC Control Products
    Last Post: 02-10-2007, 08:33 PM
  5. Aux Clnt
    By JPMach in forum Haas Mills
    Last Post: 08-17-2006, 05:29 PM
