586,312 active members*
4,892 visitors online*
    DEAWOO PUMA 200
    Hi, I'm New to these forums' so if I'm in the incorrect place Please tell me Thank You,
    Ok I have a puma 200 got coolants in hydraulics " 2005 alarm" - I clean out, put new hyd fluids in, started up for second
    then made a crazy sound i e-stopped it, now i get a 2001 alarm (says e-stop on or over travel occurred) now hyd's wont even try to start.
    need to clear 2001 Alarm before? or
    Thank's
    David
    Jul 2005
    380
    Re: DEAWOO PUMA 200
    You may have a wiped out pump.
    But, check breakers and fuses in the rear cabinet first.
  1. HELP DAEWOO PUMA 200
    By CNCANO in forum Daewoo/Doosan
    Last Post: 07-15-2016, 11:16 PM
  2. Deawoo Puma 10hc alarm 27
    By RP Jr. in forum Daewoo/Doosan
    Last Post: 07-16-2012, 06:31 PM
  3. Deawoo puma 2000sy y axis moved-.08?
    By 28jalopy in forum Daewoo/Doosan
    Last Post: 05-06-2012, 07:39 AM
  4. NEED HELP WITH PUMA 200
    By CNCBEN in forum Daewoo/Doosan
    Last Post: 09-16-2009, 04:52 PM
  5. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
