Hello
I have a problem using the "Machine Tool Builder".
Steps I did:
1. First of all, this is my 2axis Lathe Machine(XZ). I have defined 6 tool holders in 2 customs turrets. (picture 1)
2. In another part, I have machined a piece with a lathe tool with the following properties:
Tool Number = 5
Adjust register = 5
Customs Register = 5
insert position = Underside
Holder Hand = Right
Holder Style = L-Style
3. When I "Verify Tool Path" the program, it is correct according to the machining image. (picture 2)
4. When I select and import the machine from the library, tool number T5 does not fit in correct place. (picture 3)
5. I transfer the position of the tool from T1 to T5 and again run the "Verify Tool Path", and everythig seem OK. (picture 4)
6. Finally, when I select and run it in the "Simulate Machine",(Rough_TURN_OD_OK operation), the toolpaths move to the positive side of X. (picture 5)
Please help me with this.
Thank you very much
