Does anyone know how to back-up the parameters to go through every page and download or is there something that's allow you to do it all at once?
Fanuc #????
User parameters?
Option parameters?
Albert E.
Pretty much everything just in case something gets messed up..
Still need the Model#?
Albert E.
What type of machine, Mori's overlay has an easy way....check your operators manual if you have one.
Not only is there a way, but you really should do that before and after any changes!
I hate deburring.....
Lets go (insert favorite hobby here)
Oooops, 11M , Kitamura
System in EDIT mode
press SERVICE - PARAM - press PUNCH then ALL.
I am not sure if that outputs the 9000 options, I don't have my notes with me, you would have to check the parameter file and at least record these in hard copy.
Al.
Albert E.
Like a Charm...thanks again AL!!
The pc parameters do not punch out.
Make a copy of the counters, keep relays, data tables, timers.
Or use a camera and take a photo of them.
is that the nc/pc parameters?
The 9000 option parameters are not password protected only PWE bit protected in P8000 = all ones
I am sure I downloaded them once before on the 10/11/15 etc.
I know you can upload them via a PC.
Al.
Albert E.
Press the nc/pc pushbutton.
This will take to the pmc page.
Select pmc prm
we have okuma & howa act-4 0TC Series Fanuc Controller. While switching on mahcine got system alarm 911 Ram Parity(HIGH). Further entering three alarms are shown as follows
1) 100 - p/s alarm
2) SERVO ALARM : X AXIS DGTL PARAM
3) SERVO ALARM : Z AXIS DGTL PARAM.
Dont have back up of this machine parameters. Please guide and support for running machine.
