586,103 active members*
3,359 visitors online*
Results 1 to 6 of 6
    Dec 2011
    63
    Cannot move any Axis
    Hello, everyone.
    I had to build a new PC for my hobby CNC. I installed Mach 3 as I did before on a Win7 Pro. I'm using the same Gecko 540 for the controller. I thought my add-in LPT card was bad so I purchased another one. I still had a Red light on the Gecko. I know that some add-in cards don't provide the 5 volts needed for the Gecko so purchased a voltage buffer card, which is in between the PC and the 540. I now have a green light on the Gecko.
    I had saved the profile I used to run the CNC, so I added that to Mach 3, thinking it would be/should be plug-and-play since nothing has changed on my CNC setup. Well, it didn't work. I did the Driver Test which worked as it should, but still no love. I then tried the G540 xml file that is provided by Gecko, which should allow me at least to get the CNC started, but no luck with that, either.
    Any thoughts or ideas from this great community? In any case, thanks for your time in checking this out.
    Re: Cannot move any Axis
    If your Windows 7 Pro is 64 bit, you can't use the parallel port.
    Dec 2011
    63
    Had I done a bit more research I would have known that. I much appreciate it.... you saved me a lot of time.
    Dec 2011
    63
    I'm using Win7 Pro, x32.
    Dec 2011
    63
    Quote Originally Posted by zappafan1 View Post
    I did check, and I'm using 32 bit.... the same as I used before.
    Apr 2023
    You won't be able to use the parallel port if your version of Windows 7 Pro is 64 bit.
    geometry dash unblocked
  1. Hitachi Seiki Z-Axis ITZ Input Off, Z-axis will not move
    By markalbert70 in forum Hitachi Seikis
    Last Post: 10-09-2017, 07:28 PM
  2. Y axis doesn't move while all the other axis move...why?
    By Elsa in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2014, 09:41 PM
  3. Y axis will not move
    By joeyjrc in forum Tormach Personal CNC Mill
    Last Post: 05-26-2013, 05:11 PM
  4. B Axis move
    By JS TRIDAN in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-22-2013, 02:55 PM
  5. Replies: 7
    Last Post: 01-22-2013, 07:14 PM
