Re: Running spindle slower than listed speed range what will happen?
If a high speed spindle is ran lower than the rated speed it will overheat, or likely to. With burn out possible.
The hi-speed variety are constructed with less iron in the stator, therefore do not posses the inductive reactance required at lower speeds in order for the current to be sufficiently low.
All you have is the actual resistance of the winding, which is extremely low.
Albert E.
