586,471 active members*
3,598 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Modifying a Post
    Mar 2022
    Question Modifying a Post
    Hello,
    I need help to modify a Fanuc post on AlphaEdit such that the post assigns N line numbers to every tool change in the code.
    If anyone could advise me on how to make that possible it would be much appreciated.
    Thanks in advance.
    Dec 2005
    68
    Re: Modifying a Post
    did you find how to do it ?
    Apr 2010
    89
    If you only want line numbers at the Tool Change and nowhere else remove all the N[N] codes in the Post using Replace (Find and Replace text),
    then search for the $80 section of the Post and place a N[N] at the beginning of the line in that section you want the line number.
    i.e.
    $80 Select new tool. Use [T] for new tool number, [S] for spindle speed.
    ( [TNM] )
    N[N] T[T] M6
    G90 G10 P[OFS] R[TL]
    then search for the $715 section of the Post and change the Line Start Number to what you want
    i.e.
    $715 Line start number
    10
    and the Line Number Increment to what you want
    i.e.
    $716 Line number increment
    10
    Dec 2005
    68
    thanks i will be change the post
    Nov 2022
    Question Re: Modifying a Post
    Hello. I need a little modification too.
    I want to add nested sheet with and height at begining as info.
    for example
    (3200x1250)
    is there a variable ?
    any advise appreciated.
    Thank you
  1. Modifying Post
    By zachf in forum BobCad-Cam
    Last Post: 10-03-2017, 08:44 PM
  2. Modifying 5 axis post
    By carbidecraters in forum Mastercam
    Last Post: 10-23-2011, 12:26 AM
  3. Modifying a post
    By MikeA in forum Mastercam
    Last Post: 11-25-2010, 08:09 PM
  4. Need a little help with modifying my post .
    By hall6ppc in forum Mastercam
    Last Post: 07-30-2009, 05:33 PM
