586,111 active members*
3,286 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > When is spindle nose pressurization for on a spindle for wood
Results 1 to 6 of 6
    Jan 2013
    228
    I am looking at a new to me spindle with ATC for my machine. It has an air connection labeled as "Spindle Nose Pressurization". My current ATC spindle does not have this connection. The spindle is coming off a wood routing machine. The only thing I can find when I google is that it's for keeping coolant out of the spindle nose bearings. But coolant isn't used on a wood machine. So what does this do on a wood cutting spindle?
    15362
    Re: When is spindle nose pressurization for on a spindle for wood
    Quote Originally Posted by TTalma View Post
    It's not really pressurized, it is free flowing to keep the dust and chips out of the spindle bearings, this is very common for any type of CNC machine to have, quite often the air flow is also carrying a lube as well to lube the spindle Bearings, if it is a woodworking spindle then it would only have the air flow, this has to be dry air as well or the Bearings can be damaged if you have water in the compressed air
    Mactec54
    Jan 2013
    228
    SO I would only need a few pounds of air at this connection. It requires 90 for the tool change, so I could add a reducer.
    15362
    Just a pressure regulator and a solenoid air valve that would turn On / Off with the spindle may need a timer as well as the air normally flows after for around 30 seconds the spindle has stopped, they normally use 15 to 17 PSI
    Mactec54
    Nov 2012
    1267
    In woodworking machines I have seen, spindle pressurization was on all the time, even with AC power off. As long as the machine has air, the spindle is pressurized.
    15362
    Quote Originally Posted by CitizenOfDreams View Post
    You would not want air running through the spindle all the time, this would be expensive, to run a compressor and air drier to serve no purpose
    Mactec54
  1. What Spindle Nose is this. HELP!!
    By Cartierusm in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2017, 06:34 AM
  2. Spindle Nose Alingment
    By Prozesstech in forum Cincinnati CNC
    Last Post: 07-08-2016, 03:23 AM
  3. What is spindle nose? How do you know exact size SPINDLE NOSE? A2-6, A2-8
    By cjchands in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2013, 06:55 AM
  4. Identify this spindle nose?
    By serriadh in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2010, 03:46 PM
  5. LB-15 spindle nose
    By nlh in forum Okuma
    Last Post: 02-04-2010, 10:16 PM
