586,121 active members*
3,415 visitors online*
    What to mount linear rails to?
    Hi!
    I'm currently working on the first steps towards designing a 3 axis CNC mill and have a pretty basic question regarding linear rails: What should I screw them to?
    As far as I understand linear rails they are best used fully supported and that supported materials should be what gives the system the "flatness" constraints. So I need some kind of pretty flat materials that has good dimensional consistency between different parts to mount my rails to. I sadly don't have the tools to machine a material flat, so I'll probably be stuck with some kind of aluminium extrusion.
    What should I use? Simple square tubing or one of these extrusions with T-channels on all sides? Or should I bolt raw plate to the frame and attach the rails to that?
    I'm basically asking: an what type of aluminium should I expect the best tolerances out of the box?
    Jul 2018
    6341
    Re: What to mount linear rails to?
    Hi CC - A CNC mill requires very good foundations for the rails. Before I answer your Q what do you intend to do with the mill? and what accuracy are you aiming at? 0.1mm 0.01mm? 0.001mm Peter
  1. Replies: 17
    Last Post: 08-16-2015, 06:48 AM
  2. Replies: 1
    Last Post: 05-04-2011, 05:16 PM
  3. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
  4. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
