586,103 active members*
3,183 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2003
    1754
    nc400 contraves servo amp manual/schematic
    Wondering if anyone had schematics/manual for contraves nc400 servo amps. This is on an R2E3 Bridgeport.
    thank you
    sam
    Jul 2005
    409
    I have a copy of the manual at home, I will try to scan that tonight, are you just looking for the wiring diagram?
    I have (2) series2 R2E3's
    Cutmore
    Jul 2003
    1754
    what ever you can find relating to the nc400 would be great - thank you
    Jul 2005
    409
    Contraves servo amps
    Sam,
    I brought the manual with me to work, It is pretty thick and I did not have time to scan it last night. Is there anything in particular you want to know, I will look it up today. Otherwise give me a few and I will try to scan the manual. T
    The company who I think supports these drives is Cleveland Machine Controls, at least the manual is by them. The Phone # on the manual is 412-261-8600 They are in Pittsburgh P.A.
    Cutmore
    Jul 2003
    1754
    thanks, I'm looking for anything that could explain how/why the fault light comes on. I checked the tach signal and it looks great, and the power is good, trying to figure out what to check next, maybe the manual has suggestions
    If there are any schemantics/hookup diagrams also would be great.
    sam
    Jul 2005
    409
    Sam,
    there are a number of things that can cause the drive to fault, 1st the drive will show a fault when the Bport is 1st powered up untill you enable the drives, If the voltage is too high or too low to the drive it will fault(these drives seem very sensitive to this) A limit switch will trigger a fault. The drive overheating will cause a fault(mine did this because 1 of the cooling fans died) There is also a fuse on the drive or the card cage.
    You say the fault light comes on but, when and can you enable any of the drives and are there any other fault messages/ codes/
    The wiring diagram is not too clear and I know i have a clearer copy some where but Check to see the 24vdc fuse is not blown also as that can cause the drive to not be en-abled.
    Cutmore
    Jul 2003
    1754
    You wouldn't happen to know spec voltage range these amps take do you?
    (what is too high and what is too low)
    thanks
    Jul 2005
    409
    Sam,
    I checked the manual and too high is 122v or more, too low looks like 55v or less.
    What is your Bport doing or not doing? Maybe I have had the same happen to 1 of mine.
    Cutmore
    Jul 2003
    1754
    The z axis is randomly faulting. Only when it isn't moving. we swapped the x and z drives and the problem stayed with the z axis.
    sam
    Jul 2005
    409
    If you swapped the drives and the problem stayed, that rules out the drive pretty much. I would clean all the terminals for the drive, check the brushes in the servo motor, all the wires for the servo and encoder and limit switches. I had a similar thing happen and found some frayed wires on a limit switch. Mine would fault during or after a rapid move.
    Maybe try wiggling the cables with the drives en-abled to see if it faults.
    Cutmore
    Dec 2005
    3319
    I"m pretty sure that the CMC number in Pittsburgh is no longer valid.
    CMC bought out Motion Science as well - they used to be in Pirrsburgh too and the number is MIA.
    As strange as it may seem, Cleveland Machine C0ntrol is now located in Cleveland, OH. I got the number from whitepages.com via the business section look up tool.
    24221
    Quote Originally Posted by NC Cams View Post
    Its also listed on their web site!
    Al.
    Albert E.
    Nov 2006
    22
    Smile I have a Operations and Service Manual for the NC 400 Series
    We recently replaced these units with Advanced Motion Controls 50A20 drives. It worked well for us. However we have a mill that was upgraded o PC control, I don't know what the old computer needs to work offhand. We have a copy of the manual and 2 working, and 1 not working, amplifiers that where replaced with the 50A20.
    Aug 2005
    88
    Nc400
    I have a contraves nc400 servo drive as well. I am trying to find out if they will work the the skyko Pixie 100. Anyone have any Ideas. According to pixies documentation the Drive must use either +/-5 or 10 volts and operate in current torque mode. Does anyone know if the nc400 fits this discription?3
    Vince
    Sep 2007
    72
    cut more, It seems any NC400 amp info is sacred among those who may have it. All searches "zero info," any scanned manual, schematic, alignment sheet, or link to this info, would be greatly appreciated.
    Paul
    Sep 2007
    72
    Smile
    Thanks.
    Jul 2005
    409
    MRboss8,
    I have the manual for the Contraves NC400 Amp. Is there anything in particular you are interested in?
    I just have not had time to scan the manual yet.
    Regards,
    Cutmore
    Sep 2007
    72
    Cutmore, thanks for the response. I suppose the "schematic" and "pot alignment and or adjustment proceedure" while under power, in my machine, would be most welcome.
    Sincerely,
    Paul
    Jun 2008
    Do you still have the manual for contraves nc400 a1520?
    Jul 2005
    409
    I started scanning the manual last night,
    I will have some of it tomorrow and will either post it or PM it.
    Patience my friends, I will get it scanned, I just don't have a lot of free time with a full time job and my own company.
    Cutmore
Page 1 of 2 12
  1. CONTRAVES NC400 dc servo
    By bertcnc in forum Servo Motors / Drives
    Last Post: 09-15-2020, 04:00 AM
  2. Need NC400 controller data
    By MojsterMiha in forum Bridgeport / Hardinge Mills
    Last Post: 09-12-2007, 07:36 PM
  3. Need (manual, schematic...) for Servo Dynamics sd1525-10
    By DaSnake in forum Servo Motors / Drives
    Last Post: 07-28-2007, 12:15 PM
  4. Contraves dc servo driver NC400 - data?
    By MojsterMiha in forum Servo Motors / Drives
    Last Post: 09-03-2006, 02:36 PM
  5. Replies: 9
    Last Post: 01-02-2006, 05:30 PM
