586,067 active members*
5,340 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > 2021 ST20Y Threadmilling a Bolt circle on the face
    Jan 2014
    3
    Wondering how hard it will be to threadmill on the face of a part. 8/32 thread .328 deep 5.5" PCD , Material 253 MA stainless. I have not tried to do this on the lathe yet.. Using Fusion to program. Any pointers ?
    Dec 2013
    5717
    Re: 2021 ST20Y Threadmilling a Bolt circle on the face
    I was curious so I just tried it. Very easy to set up in Fusion. I used the Harvey Hole Making and Threading library to select the tool, took me a bit to find the correct tool from the list. For the operation choose Drilling, then from the Cycle tab, choose Thread Mill. Was able to generate the tool path in a few minutes. The simulation looks good.
    Now putting this into actual practice on the machine might be a bit more tricky, but Fusion has pretty good post processors for Haas machines. I guess I would start out with the recommended feeds and speeds and adjust from there as needed. Buying a few extra thread mills might be a good idea. Air cuts to start with would be a good plan.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2014
    3
    Thanks Jim. I have been doing it in the vf4 all day as a second op.I am about to sit down and re set it up in fusion for the lathe.
    I will look into that harvey library. i use lakeshore for tools but the numbers should work.
    Chris
    May 2015
    686
    NYCNC has a F360 video tutorial on threadmilling I followed it and got perfect results first try.
    Allied Machine & Engineering have a nice little guide for threadmilling they offer for free which is worth getting.
    First thread was M8 metric thread 10 mm deep in ally
    Rod Webster
    www.vehiclemods.net.au
  1. Bolt Circle Calculator
    By CNCHobbyRouter in forum Mechanical Calculations/Engineering Design
    Last Post: 03-06-2014, 11:39 PM
  2. Bolt Circle Programming
    By Isureamcael in forum G-Code Programing
    Last Post: 07-15-2008, 03:23 AM
  3. macro bolt circle
    By jdsmith0524 in forum G-Code Programing
    Last Post: 05-17-2007, 01:09 AM
  4. I Need Help G Coding A Bolt Circle
    By capitalv in forum G-Code Programing
    Last Post: 02-25-2007, 10:41 PM
  5. bolt hole circle
    By sanddrag in forum Employment Opportunity
    Last Post: 01-23-2007, 01:52 PM
