586,065 active members*
4,579 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > More of an encoder question for g320x drive
    Good morning everybody, so I’ve got a question for those who are familiar with what types of encoders work with gecko’s g320x drives. So originally when I first hooked up my drives, I had 3 Dynapar f14(2000/0330X03), 2 of which worked fine, and the third was broken. So I placed an order to replace it, but not only was it a little pricy, it had a lead time of over a month. Being as impatient as I am, I decided to leave the order active, and in the meantime I found someone selling NOS (new old stock) baldor OE0316A02 encoders for 30$ each. So I ordered 3 of them to use until my Dynapar showed up in the mail, and if they worked good enough, I was going to cancel the Dynapar and save 250$ But none of the baldor encoders are sending any kind of signal back to the drive, according to my oscilloscope. So I’m wondering if someone can make an educated guess as to if the problem is because the baldor encoders use a type of output not compatible with my g320xs or if it could be as simple as maybe needing a pull up resistor. Sorry I can’t give more info on the new encoders, I can’t find any spec sheets or install guides anywhere on the internet If someone has any ideas I can try I’d appreciate the wisdom
    Dec 2013
    5717
    Re: More of an encoder question for g320x drive
    Do you get any output when testing on the bench without connecting to the drive? The Baldor OE0316A02 seems to be a standard 5V, 4 channel quadrature output.
    Jim Dawson
    Sandy, Oregon, USA
  1. G320X Drive question
    By sammy10 in forum Gecko Drives
    Last Post: 01-31-2022, 08:59 PM
  2. G320x with CUI AMT102-V encoder
    By tindur87 in forum Gecko Drives
    Last Post: 10-13-2013, 02:23 AM
  3. G320X and Encoder Failure
    By Bob La Londe in forum Gecko Drives
    Last Post: 03-12-2013, 01:07 AM
  4. Connect encoder to G320X
    By asuratman in forum Gecko Drives
    Last Post: 10-30-2012, 06:05 PM
  5. Differential encoder e5 with the g320x
    By dgalaxy in forum Gecko Drives
    Last Post: 08-28-2009, 09:53 PM
