586,102 active members*
3,246 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Is it possible to increase the x travel?
    May 2006
    309
    I recently bought a Taig ball screw mill and it has a shorter x travel than the old standard mill. Are there any thing to do about that? Will it be pssible to cut the end stop plate in any ways so it goes a bit longer?
    Jan 2018
    1516
    Re: Is it possible to increase the x travel?
    Depends on how it was built.
    Anything could be in the way, even the ball nut head itself.
    Need decent images.
    Sep 2006
    6463
    I think you will need a longer ball screw but that will only be practical if the end support bracket (one one end) can be extended to give you a bit more travel.....how much more travel will depend on the design of the machine itself.
    The CNC mill I have was fitted with a double ball nut on the X axis and that meant having an extended end support bracket specially made for it.
    Ian.
    May 2006
    309
    My old standard mill didn´t have any stop plate at all at that side so the end of the screw hang freely in the air at that side and that allowed the x slide to travel 4 - 5 cm more. My thought was that it maybe was possible to cut the stop plate and the plate it run into in a way that allow the stop plate to drive through that area and further inwards towards the nut like the standard x slide did.
    Here is a picture of the standard x slide end and as you can see there is no stop plate there.
Name:	taig mill x axis end.jpg
  1. Taig modification to increase Y axis travel
    By Eldon_Joh in forum Taig Mills / Lathes
    Last Post: 07-28-2021, 03:14 AM
  2. Anyone increase their z axis travel 6040?
    By jimmineycricket in forum Chinese Machines
    Last Post: 03-29-2014, 05:16 PM
  3. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  4. CNCFUSION Deluxe kit--Increase axes travel
    By Crevice Reamer in forum Benchtop Machines
    Last Post: 01-06-2010, 06:24 AM
  5. CNC Fusion and Hoss travel increase mod
    By Clot in forum Benchtop Machines
    Last Post: 04-26-2008, 03:37 AM
