586,108 active members*
3,088 visitors online*
    Feb 2011
    54
    Macro for Renishaw probe to align 4th axis
    Hello fellas.
    I am trying to automatize the process of measurement and adjusting on a machining part on 4th axis Haas Ec1600.
    I will give you an illustration so you can visualize what is my problem.
    When measuring a tube I need to machine from both sides, I need to align the angle of the tube to be parallel with spindle. When setting the article, I need to use Renishaw probe to find center of each end of the tube, in relation to the center of rotation of the 4th axis table.
    I am looking for a tutorial to manage macro for this machine, which will measure each inner diameter of the tube and automatically adjust the 4th axis to put the machining tube as parallel as possible with spindle.
    Any help would be appreciated.
    Thank you
    Marko
Name:	Macro position.jpg
    Aug 2007
    414
    Re: Macro for Renishaw probe to align 4th axis
    How accurate is the repeat accuracy when clamping?
    Is the part clamped to the center of rotation?
    Can you give some dimensions of the part?
  1. Hurco Renishaw Macro - Probe Programming
    By Bogger24 in forum HURCO
    Last Post: 05-12-2021, 12:01 PM
  2. Replies: 1
    Last Post: 08-01-2018, 02:07 PM
  3. Replies: 0
    Last Post: 08-28-2014, 09:40 AM
  4. Auto align B-axis (rotary axis) using probe
    By pwilson101 in forum Parametric Programing
    Last Post: 02-06-2012, 02:53 AM
  5. How do I tram/align the 4th axis to tailstock?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 10-30-2006, 02:25 PM
