587,011 active members*
3,875 visitors online*
    Apr 2022
    Bumps on curves laser lines
    Chinese 80w Trocen AWC laser has always given me rough cuts or lines. I've tightened pulleys, cog screws and belts but still get the bumps in exactly the same place when doing a circle.
    If I reverse the line path they are still in same place. I've redrawn the circle in Lightburn and ran again.
    I'm using Lightburn but also sent file with RDWorks and have same issue so it must be mechanical
    Any help would be greatly appreciated..
    Attached Thumbnails Attached Thumbnails C8B29704-EC83-4C9D-BA49-C630BA076468.jpg
    Feb 2022
    20
    Re: Bumps on curves laser lines
    Question!
    If you move the circle to a different location on the laser bed does it follow?
    If it does I believe that would rule out mechanical
    Either way I would be inspecting each cog of the belt for debis and broken cords in it.
    Sent from my SM-G988U using Tapatalk
    Feb 2022
    20
    You know looking at it closer it could be a loose coupling on the X axis
    Nov 2008
    643
    You should be able to cut a circle out and spin it a full rotation in the wood it came from. That is most likely a mechanical problem.
  1. Laser cuts straight lines slower than curves or circles.
    By MCobb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-23-2018, 03:27 AM
  2. Laser machine not cutting straight, leaving bumps
    By RFG88 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-17-2018, 03:26 PM
  3. Reducing Lines/Curves/Splines
    By tmorrison in forum Mastercam
    Last Post: 08-06-2017, 09:08 PM
  4. Bumps in laser cut curves
    By scottgeorgeson in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2016, 06:53 PM
  5. convert short lines to curves
    By adscnc in forum Solidworks
    Last Post: 01-29-2010, 04:26 PM
