586,108 active members*
3,236 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam mill turn Mazak
    Sep 2007
    39
    Question Mastercam mill turn Mazak
    Hello all,
    I have a piece of code giving me fits and stopping progress. Its a "G43.4" Tool Tip Control (Type One) O]. I am using various toolpath types inside the Mastercam Mill Turn machine definition, for a Mazak Integrex i-300. So far all my choices of parameters inside those toolpaths gives this code and the machine alarms out, Any help out here would be greatly appreciated. :drowning:
    Re: Mastercam mill turn Mazak
    That sounds just like the G68.2 on a Makino HMC. Your mdd and control file's is probably difined a little wrong. It could be your post also. Unless your doing some true 5 axis programming you can have that tool path control turned off for now. That would get you going.
    Apr 2003
    3578
    I would start looking at the Machine Application Guide. We include this to help with things like this for the pacific Machine control file.Now I am including a screen shot from a Integrex i-300 1000U but it is located in the same location in all Machine Environments. now if you do not find what you need in here. reach out to your reseller make sure you have the latest Machine file for your machine.
    So you know Rick , this is not your standard machine PST and Control Def and Machine def configuration. This is a MT machine to start and he is using a Machine environment. this file contains everything in one location. review second picture taken from Code Expert that opens when machine is loaded.
    Machine environment seen in Code Expert.
    Attached Thumbnails Attached Thumbnails i-300 apps guide.jpg   Machine info for i-300.jpg
    Cadcam
  1. MILL TURN MASTERCAM DEFAULT NOT AVAILABLE
    By LUCIFERNIETZSCH in forum Post Processor Files
    Last Post: 05-13-2021, 01:34 PM
  2. Postprocesor for mazak integrex turn mill
    By zarif in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-05-2017, 04:20 AM
  3. Mazak post for mill turn
    By cgmaster in forum Autodesk Post Processors
    Last Post: 03-02-2017, 11:55 AM
  4. Will mastercam do Mill/turn programing???
    By mroy0404 in forum Mastercam
    Last Post: 03-05-2010, 07:57 PM
  5. Mastercam X and multispindle mill-turn machines?
    By nemat0de in forum Mastercam
    Last Post: 01-25-2005, 09:37 PM
