586,104 active members*
3,373 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Router opportunity with a few unknowns
Page 1 of 2 12
Results 1 to 20 of 22
    Apr 2014
    17
    Hi all,
    I have a crazy opportunity to get myself an 4000x2000mm ATC router.
    It does have some issues but at a price per kg it's more than a bargain!
    The specs are:
    Dimensions: 4500x2500mm (working area 4200x2000x200mm)
    Spindle: HSD ES 330A 4.5kW Air cooled ATC ISO30
    VFD: Omron (Yaskawa V1000 3phase)
    Servo drive: Omron (Yaskawa SGDH 08AE-S-OY + NS100)
    Servo motor: Yaskawa SGMAH-08AAA61D-0Y, 750W, 200V, 3000rpm
    Servo gearbox: Wittenstein alpha LP 070-M01-10, 1:10
    Control unit: Osai 10/510
    Rack and pinion: helical approx 20mm wide, not sure about exact dimensions
    Linear rails: PMI-AMT 25 table, PMI-AMT 20 gantry, not sure but i presume 15 or 20 on the Z axis
    Tools: Linear ATC 12 positions ISO30
    Vacuum: 2X Becker 5.5kW pumps, 4 vacuum zones (electronic actuation of individual zones)
    Air/Mist coolant: electronic actuation
    Automatic tool measuring mounted on table frame
    All accessories are 24V
    Construction is very robust, i don't have exact numbers but I would say table is made of 150x180mm steel RHS, table braces 100x100mm steel RHS, gantry is around 280x250mm steel RHS. Not sure about wall thickness, but it's quite thick.
    The main issue is control unit. It's Osai 10/510 and its on it's last legs.
    I Have 99% decided on UC300ETH-5LPT + UCBB breakout board + 2xIDC26-IDC26 cables + free UCCNC license key. For 212€ that is hard to beat. Other options were Acorn and Masso but they are at least 3X in price.
    I do have concerns about number of relays that I'll need
    Is there an option to run servos with modbus? and what would be the advantage vs pulse/dir?
    Essentially I need to replace the control unit and rewire everything, I'm not sure if that is possible and to what extent.
    The bonus is that machine schematics are lost (I'm trying to obtain a copy as that would make things much easier)
    Any experience? advice? comments?
    Re: Router opportunity with a few unknowns
    I wouldn't be trying to save $500 on what sounds like a $100K machine. Just saying. And I'm a UCCNC user.
    No, you can't run servos with Modbus.
    Do those drives accept Step/Dir control?
    Apr 2014
    17
    Well, it was a 100K machine back in 2009! which is why i'm so excited to get it at scrap metal price.:banana:
    I did find a few examples of people running old SGDH drives with step/dir and as far as I can tell it's just a matter of configuring drive to run of those instead of modbus. The NS100 is obsolete as it's used for modbus connection between drives and for returning values to control unit.
    I'm planning to have a dedicated computer for this CNC anyway so what would be the benefit of Masso or Acorn compared to UC300ETH?
    They all have very similar capabilities, and all use their own software. The reason I'm leaning towards UC300ETH is their user base and forums, a lot of my doubts have already been solved by someone.
    What would you suggest for a controller?
    Mar 2016
    22
    MASSO, but then I’m biased to MASSO.
    Sent from my iPad using Tapatalk
    My preference is UCCNC, which is what I use.
    Apr 2014
    17
    As I mentioned they all have very similar capabilities which are far beyond what I really need, so it comes to small subtle preferences that everyone would rank different.
    I managed to find most of my doubts already resolved and I like how UCCNC works and looks
    connecting SGDH yaskawa drives:
    https://www.cnczone.com/forums/servo...57229-cnc.html
    This is the same series only smaller, it takes sigmawin to change the parameters and re-tune the motors
    Connecting V1000 VFD is covered so many times, for connecting and reading current rpm over modbus/usb
    I found the exact tool change procedure macro on a cncdrive forum that also uses fixed tool length probe, so it's just a matter of changing some coordinates and pin numbers
    This machine will require A LOT of work, it was very poorly maintained and it will take a fair bit of parts to get it perfect.
    First thing is the linear bearings, Z axis is good, on gantry they would need cleaning and lubrication, but on the table they are beyond repair and need to be replaced. Pneumatic system has never been touched. Rack and pinion on the table is also a big question.
    Essentially I plan to take everything apart, test, repair/replace and reassemble, while it's in pieces it would be good to put a fresh coat of paint on everything.
    Jan 2018
    1516
    The UC300eth, ucbb, are great bits of kit.
    Although 300 could do with more inputs afaic.
    Apr 2014
    17
    As the OP said, the opportunity was too good to be passed, so I did it...
    From the current perspective it's not so bad, but at the time machine looked very bad (hence the price).
    The overall neglect, dirt, grime, coupled with few controller issues made it obsolete in the company.
    But, i knew that deep down, it was still a good machine
    So I took a better look at all the components, and it was all very solid (expensive) components that can work for many years more...
    Apr 2014
    17
    Anyway, few more images from back in 2022...
    So the electronics even though old, are still in decent shape, and very neatly put together (I do have all schematics of the machine)...
    Apr 2014
    17
    Anyway...
    The main thing was neglect, and that shows on the outside (even though all components were there, some panels were taken off, and the machine was used as a table when not in use)...
    Apr 2014
    17
    there was paint and silicone all over machine, but that's just cosmetic...
    Attached Thumbnails Attached Thumbnails 20220901_131633.jpg   20220901_131648.jpg
    Apr 2014
    17
    And a few concerning mechanical issues...
    Apr 2014
    17
    Now that's all great, but it's a big machine, where are you going to put it???
    Errr... I have... A shed???
    :idea:
    Apr 2014
    17
    And so it begins...
    A small excavator and the shed was no more, and the everything was prepared for foundations, and the main slab...
    Apr 2014
    17
    3 trucks of concrete for foundations and 2 trucks for the slab, we were getting somewhere.... (and a sh... load of rebar steel at covid prices)
    Apr 2014
    17
    And just as I was building walls... the new machine came to factory and the old one had to go! NOW!
    Apr 2014
    17
    Anyway... This meant that I had a machine and I was building a workshop around it! Not the most conventional was but nothing about this is...
    And since it will be some time before finishing walls and roof, i covered it...
    Apr 2014
    17
    Eventually the roof came so it was starting to look like workshop...
    Apr 2014
    17
    And just like that, the roof was done...
    Now to close the openings and on with electrical installation...
    I have to transfer photos, but the machine is currently operational...
    anyway, to be continued....
    Apr 2018
    134
    Quote Originally Posted by D_moll View Post
    That approach certainly make it easy to fit the machine through the doorway -- just have the crane on the truck place the machine where you want it!
    Nice work!
Page 1 of 2 12
  1. I have an opportunity
    By cuttingedgepart in forum Tormach Personal CNC Mill
    Last Post: 11-27-2013, 05:44 PM
  2. Emplyment Opportunity
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 06-24-2011, 04:23 PM
  3. job opportunity
    By mishikwest in forum Employment Opportunity
    Last Post: 01-08-2008, 06:22 PM
  4. Employment Opportunity
    By NWCNCHR in forum Employment Opportunity
    Last Post: 04-15-2005, 05:57 PM
