586,114 active members*
3,371 visitors online*
Results 1 to 2 of 2
    Apr 2022
    3
    laser engraves back to front
    Help required.
    I have a 3018 Pro cnc and i intend to use the laser to engrave on to wood worked items I make. However I have hit an issue as it engraves everything back to front!! i am using laser grbl as the medium to run it. if any one has a fix or suggestion i would be very grateful.
    Re: laser engraves back to front
    I am not familiar with a 3018 but I do own my own laser and have engraved wood quite nicely. My laser uses parameters such as pulse frequency, scan speed, reps, spot variable, etc. If you have those kinds of parameters, I can point you in the right direction- or I would love to quote an engraving project for you.
    [email protected]
