586,104 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 304 Stainless Steel Toolpath Advice
    Apr 2012
    161
    I haven't machined 304 stainless before. I know it can work harden, so I have to make sure I don't take light cuts. My stock is 0.09" thick plate. I need to cut out a few pieces that are about 1" square. I plan to enter into the piece from the side at full depth (since it's only 0.09" thick). I have a Lakeshore Carbide 3/16" 5-flute end mill for stainless (P/N 4220316). I'll use my fogbuster (I don't have flood coolant setup). I'd like to know if I should go with an adaptive toolpath that takes lots of short curved cuts, or just a contour toolpath. I know the adaptive will take a lot longer, but that doesn't matter to me. See attached screenshots:
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Oct 2006
    38
    Re: 304 Stainless Steel Toolpath Advice
    If you want the endmill to last and want to be able to run unattended go with the adaptive.
    I have slotted in 303 before but it's hard to get the chip out.(w/ air blast/mist or flood) so don't feel confident to walk away.
    I use a carbide corncob style 4flt endmill and have taken up to half cutter diam(3/16) radial cut without issue.
    Looking at your pic, I'm assuming you'll not plunge into the material in the corner.
    Apr 2012
    161
    Quote Originally Posted by BIRDTOOL View Post
    Thanks for the info. No, I'm not going to plunge into the material at the corner, I still need to tweak the toolpath a bit.
    Apr 2012
    161
    I did a test using the adaptive clearing toolpath, it worked great.
  1. 303 vs. 304 stainless steel
    By pearldiver in forum MetalWork Discussion
    Last Post: 02-06-2020, 08:45 AM
  2. stamping 304 stainless steel
    By stevethetoolman in forum Metallurgy
    Last Post: 05-05-2014, 02:16 PM
  3. 304 CRES Stainless Steel
    By Glenn Norris in forum Metallurgy
    Last Post: 08-06-2012, 09:44 AM
  4. Sieg X3 on 304 stainless steel or Titanium
    By pearldiver in forum X3/SX3/G0619/G0463
    Last Post: 11-06-2011, 12:16 PM
  5. machining 304 stainless steel
    By pauls in forum MetalWork Discussion
    Last Post: 08-01-2005, 04:37 PM
