586,106 active members*
3,062 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Biggest issue for diameter moving when machine is down for 10mins
    Apr 2007
    47
    Hey
    Like the title says.. I am wondering what could be the reason for a diameter to be on size but if the machine goes down for 10mins and no changes are made... why would the diameter of the part go .001"-.002" undersize. This is on a CNC lathe. From my understanding the spindle bearings would be the main cause but we are using Kitakos that have 4 spindles. 2 get loaded while 2 are being machined. It seems this happens to both spindles that go to the 1 head. So either both spindles have the exact same issue or there is something in the x and z axis slides or turret that would cause this? Once it runs for a bit the diameter naturally climbs up to where it was and holds fine.
    Thanks in advance.,
    Apr 2007
    47
    Re: Biggest issue for diameter moving when machine is down for 10mins
    Really no1?
    Apr 2003
    1357
    I know this is an old post, but...
    No thermal compensation on that machine?
  1. What are your biggest pain points as machine shop owners?
    By Relative-Blueberry82 in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2021, 02:21 PM
  2. Mach 3 stepper motor not moving issue
    By sheppyfire87 in forum Mach Plasma / Laser
    Last Post: 01-14-2019, 10:59 PM
  3. Basic question/issue with getting axis moving
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-05-2013, 05:12 PM
