586,655 active members*
2,676 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 3T-F on a Nakamura Slant -1 need some help
    Hi all,
    I have a new to me lathe and first one that is "industrial". I have some experience with LinuxCNC and manual turning.
    Have been spending a lot of time researching this controller and 6T as I have seen threads that they are similar. I do have some manuals but some are missing pages and others don't seem well written.
    1. I can ZRN the machine. When doing so the POS screen reads Relative U -12, W 4 ; Absolute X -12, Z 4 ; Machine X 0, Z0.(in mm) I try to X Cancel, Z Cancel to zero these out (doesn't work) I can Cancel U,W. I notice a G28 U0 W0 works in MDI whether I cancel those at home or not. Also, I notice that I can go into a manual mode and move the Z further another 4inches before over travel alarm.
    Are these behaviors correct? Can I change the Z/W ZRN point further back to get more travel? Is Machine coord in mm okay if I program in inches?
    2. This machine does have FAPT and it seems to be working. I have searched everywhere but cannot find manuals for this model or tutorials on FAPT. I have found a 3T-D manual that shows FAPT content. Would it be worthwhile getting at $150?
    I'm excited to learn and start using this machine. it was at a price that was too good to turn down even at this age.
    May 2016
    25
    Re: Fanuc 3T-F on a Nakamura Slant -1 need some help
    My lathe with a 3T acts the same way when homing. The U and W can be zeroed but not the other axis’. On ZRN my machine does go all the way to the limit switches. I’m sure you can change it but I don’t know how. Also, you should be able to change the display to inches with a parameter change, i just don’t have it in front of me.
    Aug 2019
    145
    I believe you can only manually origin the relative positions. Absolute positions can be set using G50 (G code A), work shift, work offsets, or parameters (76,77).
    Parameter 12 bit 7 covers how the preset is handled during manual reference return.
    Thanks everyone. I have spent some time with the machine and making progress.
    It did have 76,77 set to -12 and 4 so that made since. In the notes I have on it, I believe it has a G30 option for a reference point B. All I can find on that is it having to be set in parameters. I do not have the parameter list descriptions. I think this is best used to set a safe tool change position.
    Should I get rid of the 76,77 setting and preset? I plan on learning with a bunch of one off parts. I will then do a "production run" of around 1000 parts where I can see the preset being useful.
    Thanks again!
  1. Replies: 1
    Last Post: 06-11-2022, 01:32 AM
  2. Replies: 14
    Last Post: 08-07-2010, 04:29 AM
  3. Replies: 4
    Last Post: 02-17-2010, 05:55 PM
  4. Help For a Nakamura Tome Slant 3BX
    By Bordaco in forum DNC Problems and Solutions
    Last Post: 11-17-2006, 06:09 PM
