586,116 active members*
3,313 visitors online*
    May 2009
    1332
    Pull-Up or Pull-Down?
    Although I have used the pull—up/down many times in the past, I never understood what it does and I would like to know what happens when I set a switch to pull-up/down.
    Can you please explain in plain language what happens when you set a switch to pull-up/down?
    Nicolas
    Jan 2008
    1529
    Re: Pull-Up or Pull-Down?
    Mar 2017
    411
    This is a very good article to explain how pull-ups/down work.
    One must also consider the beginning state of a circuit to determine if the signal should be pulled up or down. Look at a spindle controller as an example. There is usually a signal for spindle direction and one for run/stop. Now think about what happens when you first turn the system on. The electronics power up, then the controller initializes, then you start the CAM software, then you setup the job. Between the power up and initialization of the CAM software, you want the spindle to remain in the off state. If the run/stop signal is active high and you have a pull-up on the signal then the spindle will start up and be spinning until the CAM software can turn it back off.
    What you would want to do in this case, is to use a pull-down resistor so the the spindle stays in the off state. Of course you would also have to make sure that the circuitry supports this.
    Just some food for thought.
    May 2009
    1332
    Thank you both for the headsup, very interesting.
    Now its ll clear
    Nicolas
  1. Pull studs
    By Scrambled1 in forum HURCO
    Last Post: 11-20-2016, 08:19 PM
  2. pull the screws out :)
    By deadlykitten in forum Okuma
    Last Post: 03-19-2016, 06:16 PM
  3. Pull stud?
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2011, 01:07 AM
  4. need help with pull stud
    By pper in forum Tree
    Last Post: 05-23-2011, 05:02 PM
