586,102 active members*
2,476 visitors online*
Results 1 to 1 of 1
    Apr 2022
    How Does Spark Erosion Machine (EDM) Work?
    This article is a detailed introduction for those who want to know and buy spark erosion machines, to help them understand the field of discharge machine faster.
    CHAPTER 1
    Definiation Of Spark Erosion
    The principle of Spark Erosion machining process is to remove excess metal using electrical corrosion (pulsed spark discharge) between the tool and the workpiece, in order to achieve the desired size, shape and surface quality of the workpiece.
    As shown in the figure, the workpiece and the electrodes are respectively connected to two electrodes of different polarities of the pulse power supply.
    The Materials Needed For EDM Spark Erosion Machines
    Electrode:
    Electrodes are commonly used materials with good electrical conductivity, high melting point and easy processing, such as copper, graphite, copper-tungsten alloy and molybdenum. During the machining process, the electrode will be wearing off, but it is less than the amount of removal of the workpiece metal, and even close to no loss.
    Dielectric Liquid:
    As a discharge medium, the working fluid also plays the role of cooling and chip removal during the machining process. Commonly used working fluids are mediums with low viscosity, high flash point and stable performance, such as kerosene, deionized water and emulsions.
    Workpiece Materials Selection:
    Selecting different workpiece materials according to the use of the workpiece, for example, according to different mold types. Cold die steel is generally used for spark erosion of dies. Hot die steel is generally used for electrical discharge of cavity molds. Taking aerospace industry as an example, it uses high temperature heat-resistant alloys, high chromium and high nickel alloys, titanium alloys and etc.
    Clamping And Correction Of Workpiece:
    Nowadays, 3R and Erowa tooling system are most common selecting. Because they are convenient and reliable, high repeat positioning accuracy, especially suitable for spark erosion mold production.
    CHAPTER 2
    Types Of EDM Spark Erosion Machine
    Spark Erosion is the most widely used processing method in the electrical discharge industry.
    According to the relative movement of the electrode and the workpiece, it can be roughly divided into CNC DIE SINKING EDM, WIRE CUT EDM and SMALL HOLE DRILLING EDM MACHINE.
    Among them, wire cutting processing accounts for 60% of EDM, and die sinking processing accounts for 30%. With the development of electrical processing technology, spark erosion processing has become a symbol of advanced technology, accurate cutting process.
    Wire Cut EDM Machine
    Wire EDM is divided into brass wire and molybdenum wire cut EDM. Generally, electrode wires with a diameter of 0.1mm~0.3mm are used to process straight-grained parts, which can be punch parts or die holes.
    1. The electrode and the workpiece move simultaneously in two horizontal directions;
    2. Cutting various dies and parts with ruled surface;
    3. In cutting tools, precision small parts and special materials
    Die Sinking EDM Machine
    The tool electrode is usually a copper or graphite forming electrode, which can be any shape that can be produced, and the processed shape is the corresponding cavity.
    1. There is only one relative axis movement between the tool and the workpiece
    2. The tool is an electrode, which has the same cross-section and corresponding shape as the surface to be machined
    3. Peneration processing: processing various punching dies, extrusion dies, powder metallurgy dies, various special-shaped holes and micro holes, etc.
    4. Cavity processing: processing various types of cavity molds and various complex cavity parts
    CNC Drilling EDM
    1. Use a thin tube of 0.3-3.0mm brass tube, and pour the high-pressure water-based working fluid into the tube;
    2. The thin tube electrode rotates;
    3. The perforation speed is very fast (30~60mm)
    4. Wire cutting starting hole popper
    5. Small holes with a large depth-to-diameter ratio, such as nozzles
    CHAPTER 3
    Advantage Of Spark Erosion Methods
    1. Spark Erosion machining can process materials and complex shape workpieces that are difficult to cut by ordinary cutting methods.
    2. The eroding process is hardly affected by heat, so the thermal shock layer can be reduced. Because of this the workpiece with high machining quality can be achieved.
    3. No defects such as burrs and knife marks and grooves.
    4. The electrode material does not need to be harder than the workpiece material, so it is easier to process and manufacture.
    5. High security, the working fluid of wire cutting is non-flammable.
    6. High machining accuracy Accuracy<0.008mm
    7. CNC Die Sinking EDM has excellent surface finishing Ra<0.1um, no polishing required.
    8. EDM can eliminate the vertical angle of the workpiece, no R angle.
    CHAPTER 4
    Spark Erosion Applications & Examples
    https://www.edmsammlite.com/wp-conte...1sl8lam8c8.jpg
    Tips of Selecting CNC Spark Erosion Machine
    1. Brand of EDM machine
    Brands can also represent quality, so buying a spark machine also depends on the brand.
    Recommended brands: Agie Charmiles, Sodick, Mistsubishi, Sammlite Machinery
    2. History of Spark erosion machine manufacturing factory
    The length of production history of the CNC EDM Machine manufacturing plant can tell how stable its products are.
    3. Requirements for products
    There are four main elements of CNC spark erosion machine performance: surface finish, electrode loss, processing speed, and processing accuracy. https://www.edmsammlite.com/about/
    4. The size of the processed product
    Choose edm spark erosion machines with different stroke sizes according to the size of the product to be processed.
    5. Processing technology
    Different choices of EDM machining processes are also different.
    Available in die sinking edm, wire cut edm and drilling edm (hole popper).
    6. After-sales service capability
    According to the importance and ability of the EDM machine manufacturer to after-sales service, choose China Spark Erosion machine with guaranteed after-sales service, such as Jiangsu Sammlite Macinery Die Sinking EDM Manufacturere.
    Sammlite Machinery's EDM Machine Development
    Jiangsu Sammlite Machinery was established in 2000. The company has more than 20 years of experience in electrical processing and manufacturing. The company’s main products are CNC Die Sinking EDM, CNC wire cutting machines, and Drill EDM. In addition to having a stable domestic market, the products It is also exported to more than a dozen countries and regions including the United States, Germany, Turkey, Sweden, Japan, South Korea, Australia, Poland, Mexico, Saudi Arabia, Iran, Brazil, South Africa, Colombia, Malaysia, Thailand, India, and Vietnam.
    The article reference: https://www.edmsammlite.com/about/ https://www.edmsammlite.com/how-does...-erosion-work/
    Attached Thumbnails Attached Thumbnails Spark Erosion.jpg   Die Sinking machining.jpg   wire cut machining.jpg   CNC-Drilling-EDM-with-0.5mm-copper-hole-1024x793.jpg
    automobile-pi7xsg6hzyohzg41zm3jg04s71mxh50c4l6mi65tbs.jpg   2-1P91210455Q39-pjwtcwrum6f9elmgksi1v7dt9b1rxf1ejpma4h5uq8.jpg   Small-hole-drilling-machine-pm7xf5cs3snqz7nrkm5ecxz2rb93nnjt1sl8lam8c8.jpg
