586,114 active members*
3,099 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > My DIY CNC cutting Aluminium 7075
    Oct 2016
    16
    Some info:
    Spindle: 2.2 Kw Chinese
    Stepper: Nema34 12nm Closed Loop
    Machine: Mesa 5i25 7i76, LinuxCNC 2.8
    Toolpaths: Solidcam iMachining, Roughing and Finish
    I will update this post with feed rates later and try to include them in the next video. All footage is in realtime.
    I hope you like the video and would love to have your feedback!
    You can find more info about the machine in this old thread:
    https://www.cnczone.com/forums/epoxy...27886-cnc.html
    What do you think should I make a new one? Lots of stuff has changed and I plan to share more about the machine and hopefully finally share all the files on GrabCAD. I want it to be perfect that's what's holding me off but its probably better to have a not so perfect version than nothing at all isn't it?
    15362
    Re: My DIY CNC cutting Aluminium 7075
    Quote Originally Posted by IIIDMeister View Post
    Some info:
    Looks good the mill is working well, you should run a edge chamfer before you remove your part, if you have part location on your fixture you can chamfer the back side flip it over and then machine your part and chamfer the top when finished cutting your part out. and edge chamfer makes all the difference to a finished part
    Mactec54
    Jun 2005
    1730
    The part turned out really nice. My question is will this handle the string pressure? Aluminum cut that thin is not very strong
    Oct 2016
    16
    Yes it was strong enough, I am working to these limits. But I have to change the design to get it sound right!
  1. Diy CNC router for aluminium
    By Vilyoo in forum CNC "do-it-yourself"
    Last Post: 02-27-2022, 02:12 AM
  2. Engineering help with prototype part made from 7075 Aluminium
    By AshGgeorges in forum Mechanical Calculations/Engineering Design
    Last Post: 11-09-2021, 04:14 PM
  3. Where to get Aluminium,. 6061, 7075 and other machinable alloys in Aus?
    By gregau in forum Australia, New Zealand Club House
    Last Post: 10-07-2016, 12:26 AM
  4. A Source for decent machining Aluminium - 7075 / Fortal
    By RCaffin in forum Australia, New Zealand Club House
    Last Post: 08-03-2014, 05:19 PM
  5. machining 7075 aluminium on DIY MDF CNC
    By mihaelbele in forum MetalWork Discussion
    Last Post: 07-13-2009, 10:56 PM
