587,072 active members*
3,073 visitors online*
Thread: problems
Results 1 to 2 of 2
    Feb 2008
    problems
    I'm an artist working on an piece and am having some issues.
    I want to pull a small geometric shape(3" x 1" x 3/4" high) on a piece of plexi that is approx. 10" x 13" preferably 1/8" thick clear plexi.
    The problem is that I don't want to cut the shape out of the remaining plexi. I am unable to get good definition with 1/8" plexi so I tried 1/16" plexi. The problem arose when the plexi began to suck through the vacuum holes(3/16" dia.) in the platen.
    I am using a fein shop vac, which is sufficient for the 1/16" thick plex, but doesn't seem to work well for 1/8". I'm in the process of converting a twin tank porter cable compressor into a vacuum press.
    Any thoughts would be great
    Apr 2006
    187
    The 3/16 Dia vacuum holes are quite large, try multiple 1/16 (or smaller) Dia holes @ strategic locations to help pull your material into the shape required.
  1. More DNC problems
    By jnc in forum Haas Mills
    Last Post: 05-28-2009, 12:16 AM
  2. Problems with 201
    By bryanrabb in forum Gecko Drives
    Last Post: 12-31-2007, 03:16 AM
  3. KMB-1 problems
    By MTMW in forum HURCO
    Last Post: 07-22-2007, 09:40 AM
  4. .dwg problems anyone???
    By slideleft in forum BobCad-Cam
    Last Post: 03-23-2007, 07:03 PM
  5. Problems With G02 G03 Using I And J
    By Jim Estes in forum BobCad-Cam
    Last Post: 12-19-2005, 02:22 PM
