586,116 active members*
3,313 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai SKT21 LMS Lathe Q Setter enable
Results 1 to 11 of 11
    Dec 2019
    17
    Hello, I recently purchased a 2006 Hyundai lathe with a Q setter, Fanuc controlled. The previous shop never used setters so apparently it's be disabled. I assume this is done through a parameter setting, but I've had zero luck figuring out how to turn it back on. Any help would be greatly appreciated!
    Apr 2009
    1262
    Re: Hyundai SKT21 LMS Lathe Q Setter enable
    It should be done through your keep relays. Which model of lathe do you have? They have different layouts for each model.
    Dec 2019
    17
    Interesting. It's a 2006 SKT21-LMS
    Apr 2009
    1262
    This should help you out. I think you're after D7.7 in your case.
    Best regards,
    Please let me know how it goes!
    Dec 2019
    17
    What is D7.7?
    Apr 2009
    1262
    It is a system data bit setting. Should be located in same area as keep relays under system button.
    Dec 2019
    17
    Thanks, I will search that out when I get to the shop.
    Dec 2019
    17
    It looks like the Data sheet you posted might be for a newer controller. Mine says "Fanuc i Series" and the data bits aren't matching up to what you posted. Dan
    Apr 2009
    1262
    Well, they do have a different version, but I'm not so sure it will work for your machine. Here is a copy for your reference:
    Best regards,
    Dec 2019
    17
    Those settings match what I have. I've gone in and changed D8.1 to 1. Is there anything else beyond that I should look for?
    Dec 2019
    17
    This is the alarm I get when I press the Auto Q-Setter button. The light on the proximity sensor turns on and off when I manually move the setter up and down, so I assume the sensor is good.... Not sure what could be going on.
  1. Replies: 2
    Last Post: 09-06-2023, 09:39 PM
  2. Replies: 7
    Last Post: 01-03-2023, 12:07 PM
  3. Hyundai Kia SKT20 LMS fanuc 0i
    By positiverake in forum Hyundai Kia
    Last Post: 01-23-2018, 11:34 AM
  4. Hyundai tool setter calibration
    By Dr Evil in forum Hyundai Kia
    Last Post: 04-25-2011, 10:46 PM
  5. fanuc oi-tc on a hyundai-kia skt21
    By mekdad in forum Fanuc
    Last Post: 12-11-2007, 01:01 AM
