586,103 active members*
3,362 visitors online*
Results 1 to 6 of 6
    Dec 2019
    17
    Fanuc Q Setter enable parameters
    Hello, I recently purchased a 2006 Hyundai lathe with a Q setter, Fanuc controlled. The previous shop never used setters so apparently it's be disabled. I assume this is done through a parameter setting, but I've had zero luck figuring out how to turn it back on. Any help would be greatly appreciated!
    Re: Fanuc Q Setter enable parameters
    Can you post your ladder?
    I have a Mori/Fanuc lathe. Do you have a PSM or PST button on your control panel? PSM is a center square with for small rectangles spaced around it. The PST is a circle with two vectors crossing thru it.
    It could very well be a parameter, but if I didn't have the books for my machine, I would nave never figured out that one of those two buttons turned on the tool setter.
    If it is a parameter, I'm sure the good Dr should be able to help you there.
    Dec 2019
    17
    Yes. Is there a specific parameter #/page I need to post? I'm new to Fanucs "ladder" system.
    Dec 2019
    17
    I've finally navigated to the Q-Setter Ladder and it says "Off". How do I go about turning it on? Thanks, Dan
    Dec 2009
    953
    look for a "Y" adress of the Q-Setter,that will be the condition for making work
    the "X"" adress is only the sensor confirmation of the arm if it is up or down
    for moving conditions of the arm you need to find in the ladder the equation that will end with "Y"
  1. Mazak 510C-II Automatic Tool Setter Parameters
    By AKorzan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2021, 09:39 PM
  2. Enable Macro A or B on Fanuc 6T?
    By mflux_gamblej in forum Mori Seiki lathes
    Last Post: 08-24-2018, 08:16 PM
  3. Bridgeport EZ-Trak Z-axis Disabled. How to configure parameters to enable?
    By bkjensen in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2018, 12:21 AM
  4. how to enable 48 WPC on fanuc O MC
    By joseelmo in forum Fanuc
    Last Post: 03-09-2016, 05:51 PM
  5. tool setter not working after reinstalling parameters
    By tward74 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-15-2010, 10:03 PM
