586,061 active members*
4,414 visitors online*
    Fanuc Pro P changes IO setting
    Hi all, i have a new to me machine that changes the IO channel to 15 automatically after i load a program. super annoying to go back and change it to channel 4 every time i load something. Is this a parameter that is turned on? havent seen anything in the book so thought id ask here. Machine is a 2013 Makino PS95 with the Pro P controller.
    Thanks for the help!
    P.S. Makino is no help on this without consulting an applications engineer. $$
    Re: Fanuc Pro P changes IO setting
    Makino has custom software which has the ability to control this setting. (not saying that they are) Can you post the ladder? I can verify if they are doing it that way.
  1. Replies: 1
    Last Post: 03-28-2020, 01:43 PM
  2. Simulation Pro - Setting up the Machine Definition
    By SBC Cycle in forum BobCad-Cam
    Last Post: 04-07-2019, 08:22 AM
  3. Art cam pro 9 node setting shortcut keys
    By vijaytheking in forum ArtCam Pro
    Last Post: 08-22-2017, 09:00 PM
  4. Help Setting up 4th rotary axis with Gecko 540, Mach3 and Vectric VCarve Pro
    By rdlambert1 in forum Mentors & Apprentice Locator
    Last Post: 07-23-2015, 08:28 PM
  5. setting z depth of cut V25 3 axis pro
    By phantom1500 in forum BobCad-Cam
    Last Post: 12-28-2012, 01:29 AM
