586,500 active members*
3,130 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Z axis gaining spindle problem motor gets hot. Newbie into cnc
Page 2 of 3 123
Results 21 to 40 of 55
  1. #21
    Dec 2021
    54
    First you have to have a Ground Plane, where everything is mounted too in your Box is the Ground plane, check the incoming main power supply Ground is mounted metal to metal this then Ground the Box this is important to have a Good Ground anything then that is in the box can be Grounded to a Ground Bus or stud this has to be done correctly or it will be ineffective I will post some snips of how the shields have to be Grounded
    You must remove all paint or anodizing and have bare metal for all Grounding connections
    P-Clips are best for Shielded Cable, a saddle clamp will work, both types must clamp the shield tight
    Post some photos of inside your Box / Cabinet I can see better what you have to do.
    Thanx for your help. Once i done with thesei will reply you back. Hope this solve my problem
  2. #22
    Dec 2021
    54
    Quote Originally Posted by Chmfhm View Post
    I shielded all axis wires and ground the shielded wire.
    After that i run machine but the issue of z axis was still as it is.
    After that i replace the BOB and remove spindle cables x axis cable and the y axis cable from the BOB. And also from electricity. Just Run only the z axis. But the problem with the z axis is still the same. I also changed the z axis motor. The new motor has 2.8 torque. But the problem is that it is not going to be solved of z axis.
    Also i added emi noise filter on my 220v too
    Sometimes i thought why i am into cnc thing
  3. #23
    Jun 2005
    1730
    Re: Z axis gaining spindle problem motor gets hot. Newbie into cnc
    Does this machine use a USB interface versus a parallel interface card? If this is a USB interface, my bet is you are getting EMI interference causing the z axis to move just slightly as you try to move. You might be able to resolve this by purchasing a USB isolator, which is cheap about $15 and it isolates the laptop from the machine, so no EMI can cause Mach3 to do strange things.
    Russ
  4. #24
    Dec 2021
    54
    Quote Originally Posted by CNCMAN172 View Post
    Russ
    Yes it is usb interface and usb cable is sheilded and has emi/rfi attached 6 inches from computer end connector
  5. #25
    15362
    Can you post some close up photos, of the wiring, I may see something that is causing the problem.
    Mactec54
  6. #26
    Jun 2005
    1730
    Chmfhm,
    The fact you have a shielded USB cable with ferrite beads at both ends is great but this does not isolate the PC from the CNC electrically. I had the same crazy issues going on with my USB KFLOP board it worked but would do strange little moves and suddenly lose contact and re-establish it was making me tear my hair out. Someone on Cnczone metioned USB isolators and I was out of options so I ordered one which was under $15 and plugged this little board right before the PC and the USB cable plugged into the isolator. Just like magic my issues disappeared. I still use it today. This is an example of what they look like there are many makers of these units.
    https://www.ebay.com/itm/18301419381...QAAOSwDEBcRWGU
  7. #27
    15362
    Chmfhm,
    He does not have a USB issue, or the other axis would have problems as well, there is nothing wrong with adding what you suggest, I would be very surprised if it solved his problem
    Mactec54
  8. #28
    Jun 2005
    1730
    Mactec54,
    It is true noise could impact other axis as you suggest. On my machine I had strange stuff happening only on Z axis as the spindle moved around those cables got closer to EMI sources. This also could be the weight of spindle causing motor to slip due to weight it is being asked to support. A counterbalance shock might address the issue. A good test would be remove spindle and check and see if it keeps dropping
  9. #29
    15362
    Mactec54,
    If there is EMI from the spindle, it's from incorrect wiring, he still had the problem without the spindle and other axes connected
    I think he did remove the spindle.
    If you watch the video, it moves all by itself after the machine has stopped, it's getting a signal to move from the control, this could be bad Optos as well, although he tried another Board and it still happened, it could be the stepper Drive also
    Mactec54
  10. #30
    15362
    The stepper motor may be too small for the job what are others using on the same machine as you have
    How did you Ground the Shield, there is a right way and a wrong way??
    Mactec54
  11. #31
    Dec 2021
    54
    I connect sheild with wite at motor end and that wire directly connects to ground cable.
    As i told you i remove all axis wire and also remove spindle wires from Bob and from power supply. Just z axis wire connected to bob and powr supply.
    First 57hs76 2804 motor is installed on z axis which has holding torque of 1.8nm now i install 57hs100 2804 motor which has holding torque 3nm.
  12. #32
    Dec 2021
    54
    I order usb isolator from china it will take 15 to 20 days. Meanwhile I will remove spindle from frame today and run z axis to check my problem and let you know
  13. #33
    15362
    The Shield connection is incorrect, it must be clamped at both ends as in the photos I posted, you can't use the drain wire connected to Ground, using the drain wire is ineffective and can cause even more problems that what you already have. look at the photos again this is the correct way to clamp the Shield.
    Mactec54
  14. #34
    Dec 2021
    54
    I just removed the spindle from the frame. Then place a piece of mdf under the spindle holder and zero the z axis in mach3. Then i check the mdf piece by moving it back and forth under the spindle holder. Then irun the G code. After 5 minutes I stop G code to check again. I try to place same mdf piece under spindle holder but was not able to insert under spindle holder.
    I sending you link of video you can check in start of video it is movable under spindle holder. And in last of video you can see clearly that I am unable to put back again mdf peice under the spindle holder.
    https://drive.google.com/file/d/13YhOtTQylaEcSZHMkzS3089ZMaXFtdRl/view?usp=drivesdk
    Also I swap x stepper drive with z to check whether it's a problem of stepper driver or not. But problem remain same
  15. #35
    15362
    https://drive.google.com/file/d/13Yh...w?usp=drivesdk
    What was the DRO in Mach3 reading when you started and when you finished was it at 0.00 start and finish
    Mactec54
  16. #36
    Dec 2021
    54
    Yes it is 0.0 on start and 0.0 on stop or finish
  17. #37
    Jun 2005
    1730
    Very strange issue. Since you did not have the spindle running, I am going to venture a guess this is not EMI interference, however it can still happen from other sources. I am leaning towards some kind of mechanical issue, can you check your bearings on the Z axis and see if anything in loose. You also need to check backlash on the Z axis to see if that is playing a role. Did this machine every work correctly?
  18. #38
    15362
    The video shows the motor turning after it is stopped so it is being driven by the drive, it's getting power from some where to do this.
    Mactec54
  19. #39
    15362
    So has the axis been calibrated correctly Steps/ Per could be off which could cause this??
    In MDI do this Z-1.00F20. and check to see if it has moved 1" or if you are using mm then use 25mm
    Mactec54
  20. #40
    Dec 2021
    54
    It's a new machine. Just open box last month. It is doing since day first. I will check bearing today. Also can you guide me how to check back slash on z axis
Page 2 of 3 123
  1. Problem Z Axis gaining steps
    By antennas4u in forum Australia, New Zealand Club House
    Last Post: 05-04-2018, 03:09 AM
  2. Spindle is getting HOT! Problem?
    By F15pilot in forum Spindles / VFD
    Last Post: 07-09-2015, 10:46 PM
  3. Stepper motor on X-axis getting very hot
    By tryggs in forum CNC Machine Related Electronics
    Last Post: 05-21-2012, 12:28 AM
  4. spindle motor too hot
    By slowlearner in forum Fadal
    Last Post: 05-17-2012, 04:25 AM
  5. Z axis servo motor getting really hot
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 03-10-2010, 02:53 AM
