586,061 active members*
4,456 visitors online*
Results 1 to 7 of 7
    Apr 2022
    32
    Which is X, and which is Y
    Howdy! I am a first time cnc router builder, and need some input from seasoned cnc'ers. I haver searched online, but I find conflicting answers.
    So - Which do I set up as the X axis, and which one Y ? I will have 0, 0 set at the lower left corner of the table, so it seems logical to me that Y will be the long axis - the length of the table, and the X axis will be along the gantry. Your thoughts please.
    Thanks!
    Apr 2022
    5
    Re: Which is X, and which is Y
    Great. There's nothing left to edit. drift f1 Just keep doing it
    1227
    Entirely your decision and all you have to do now is create your CAD files to suit the arrangement.
    Apr 2014
    17
    As mentioned it's up to you!
    There is nothing wrong with placing the machine in any quadrant, if it suits your needs. (1st. +x, +y... 2nd. -x, +y... 3rd. -x, -y... 4th. +x, -y)
    However.... (there is always "however" )
    While working with multiple CNC machines it could be confusing "switching" between systems.
    Most machines are in first quadrant (at least that I had a chance to work with), and that is what I find easiest, as it's a landscape design with zero at bottom left and all positive axes. (as shown in your first image). Also the machine is parked at 0,0
    Apr 2022
    32
    Thanks for the advice. 1st quadrant it will be then!
    Apr 2004
    5737
    Usually X is the longest axis. It works out better for laying things out on a monitor screen, which is wider than it is high. Most CAD programs will present you with a screen for the basic plan view that has Y going vertical and X horizontal. But it doesn't really matter much, as long as you can remember what's what.
    Andrew Werby
    Website
    Jun 2005
    1730
    The traditional CAM approach is X moves left to right with left being zero. Y moves front to back with Front being zero. This is your typical XY plot from school. You can make it work other ways as well as long as you setup your CAM and CAD programs to use the same coordinates.
