586,036 active members*
3,790 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Using HAAS G71 bolt arc using first hole as reference, not center of bolt circle.
    Aug 2015
    9
    HI,
    I need to make 5x equally spaced holes along a 8.21" R spaced at 7.78°. Stock is 6.63 "x 3.5" (Haas vertical Mill)
    The first hole is located at X1.1 Y-0.73. (Part zero is upper lefter corner of part). The problem is, with G71 the reference point for the arc is the center of the bolt circle, which would in outer space relative to the part.
    Is there a way I can manually program using the first hole as the reference? So I start off at x1.10 Y -0.73 and the I8.21 J7.78?
    Aug 2009
    1573
    Re: Using HAAS G71 bolt arc using first hole as reference, not center of bolt circle.
    Quote Originally Posted by _Lou_ View Post
    ...the XY ref center point of the bolt circle is just that...a Reference point....lol. Define the 1st drilled hole using G71 J and K in degrees (+or- I think) should work for ya.
    https://www.haascnc.com/service/code...value=G72.html
    DJ
    Dec 2013
    5717
    I would just redraw the part in CAD and reference the holes to a location on the part. Looks like all the dimensions are on the drawing so should be pretty easy.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    hy it does not matter if the reference is on outer space ... really doesn't; let's say that this center is XcYc, relative to the uper left (XoYo)
    set XoYo
    cut 1st hole at X1.1 Y-0.73
    shift reference to XcYc
    rotate program with 7.78 degrees
    cut again at X1.1+Xo-Xc Y-0.73+Yo-Yc
    rotate program with 7.78*2 degrees
    and so on
    for this to work, is needed a code to rotate the entire program; i can't help with haas codes, but maybe there is something
    normally, for whatever part, you set the wcs and go ... for this one, you need also a shift and a rotation / kindly
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. Partial Bolt Hole Circle
    By barks in forum Okuma
    Last Post: 11-25-2009, 09:41 AM
  3. Replies: 19
    Last Post: 11-11-2009, 04:48 PM
  4. bolt hole circle
    By sanddrag in forum Employment Opportunity
    Last Post: 01-23-2007, 01:52 PM
