586,075 active members*
3,982 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Stuck on Machine Configuration screen
    Apr 2008
    13
    I have a Hurco KM-3P that I cannot get past the Machine Configuration screen.
    On start up, the first thing that shows on the screen is "Executing Power Up Diagnostics - Please Wait"
    Next, It moves to the **Machine Configuration** window.
    Listed on the screen:
    Maximum X Travel 610.000 MM
    Maximum Y Travel 355.000 MM
    Calibrate Direction X Right, Y Back.
    On the bottom of that screen, it says "Caution: Machine configuration defaults have been loaded and must be verified or reset before continuing"
    The only soft key available is "8" or EXIT.
    I can "enter" or "advance" through all of the settings. I can change the Maximum Travel numbers... When I'm at the "Calibrate Direction", soft key options come up, and I can change the direction with the soft keys.
    I cannot EXIT this screen... Pushing the EXIT soft key does move the cursor, but it doesn't exit... Selecting "8" and "enter" does the same thing as just pushing the soft key.
    A comment on another website told someone to push 999 and enter, but all that does is shows (1) "9" in the first soft key box, and hitting enter, says 9 is out of range, must be 1 - 8.
    Anyone have any idea's I can try?
    Charlie
    Apr 2008
    13
    Re: Stuck on Machine Configuration screen
    Quote Originally Posted by cNcCharlie View Post
    Charlie
    Well, got that part! The 999 does work, just needs the right order of button pushing to make it happen. Tried so many combinations, I'm not sure exactly what I did when it did work!
    Jun 2008
    1104
    Press enter 999 enter
  1. HELP... Golden Laser stuck at welcome screen
    By riadi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-16-2017, 11:50 AM
  2. LC6090 stuck on startup screen, thud sound from machine
    By indrora in forum Commercial Laser
    Last Post: 03-12-2014, 07:17 AM
  3. 2007 Haas Mini Mill stuck on boot up screen
    By gangpw924 in forum Haas Mills
    Last Post: 08-07-2012, 02:00 AM
  4. 1998 Fadal stuck in MDI screen?
    By JoBwan in forum Fadal
    Last Post: 04-18-2011, 07:52 PM
