586,060 active members*
4,192 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Left milling cutter - how to use
    May 2022
    10
    Hello. There is a question to the millers - in which direction do the left cutters rotate? If the milling cutter with the direction of the grooves on the right rotates to the right, then the milling cutter with the grooves on the left rotates in which direction? Left, or right?
    Jun 2015
    4154
    Re: Left milling cutter - how to use
    hy it's possible to have the toolholder/endmills with groove/flutes straigth, to the left/right, and all those combinations will use same spindle sense
    there is no conection between spindle sense and flutes direction, thus a right tool, classical one, may have different flutes/groove geometries
    in common language, a left tool requires an opposite spindle sense, while a rigth tool uses the default spindle sense
    a right tool, with :
    ... z flutes/grove has the tendency to pull the material&chips up, and also it tends to get out of the collet
    ... s flutes/grove has the tendency to push the material&chips down, into fixture, and also it tends to go dipper inside the collet
    ... straight flutes/grove has no tendency whatsoever
    for example, think of a tap : the one for blind holes has different flutes direction in respect to another for through holes
    endmills ( cuting on side ) or reamers ( conical ) with s/z flutes : one has the tendency to smooth out cutting, while the other makes it rough, thus one tool can be more/less stable, depending on how the flutes orientation is ( + how many teeth in cut, etc ); the difference, is that cutting starts near the tool shank, while for other, cutting starts near the tool edge / kindly
    Dec 2008
    3109
    You make it bloody hard, Deadly
    L/H cutters run in a CCW direction, uses M4 (opposite to a R/H cutter M3)
    The idea was if you created toolpaths for a complicated R/H part using conventional tooling (ie. a climb mill operation), you could mirror that toolpath and use L/H cutters, you would be still be climb milling... Hole drilling operations wouldn't need reverse paths, just mirrored positions.
    Jun 2015
    4154
    hy super i think it looks "hard" because i tried to diferentiate between spindle sense and grooves direction
    nowadays a common left endmill would have flutes in opposite direction in respect to a right endmill, thus for most tool users, there is a "default" association between spindle sense and flutes direction
    but from a tool design point of view, there is no such association; demand for reversed helix has dropped considerably
    May 2022
    4
    Ohw..is it really too hard?
