586,094 active members*
3,895 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Gantry Build. The $1 mistake that started it all.
Page 8 of 8 678
Results 141 to 143 of 143
  1. #141
    Re: CNC Gantry Build. The $1 mistake that started it all.
    Ardenum,
    The surface plate is my main reference point/surface and work table. I plan on using quick change fixture plates on top of my surface and mount pallets and vise for workholding on top. The reason I am using the surface plate as an insert inside of the UHPC is that I don't have a cost effective way of getting a flat surface that size.
    I do like your steel inserts on your casting, I think my gantry is going to end up being made of steel and not UHPC. I never seen 4 rails on the Z axis before, any concern of alignment and binding? I'll have a look at your thread and download your model.
    Here is some of the sheet metal for the machine. Showing tool changer cover and some Y axis way covers, design may change a bit on these components. 70 tool changer magazine.
  2. #142
    Jul 2018
    6341
    Hi CBF,
    Rigimill MG uses 5 raails on Z Claims to be the most rigid on planet.... Peter
    https://modig.se/product/rigimill-mg/
  3. #143
    Nov 2020
    361
    Here's a fully welded frame, the z axis assembly is a stiff one, spindle box could be a little bigger but overall it's a good design(spindle box is held on the sides), this type is stiffer than what people usually do.
Page 8 of 8 678
  1. Fixed Gantry CNC build log
    By shoot in forum DIY CNC Router Table Machines
    Last Post: 09-13-2019, 10:22 PM
  2. Replies: 7
    Last Post: 12-09-2017, 01:08 PM
  3. New CNC Gantry Build
    By ny_racer_xxx in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-24-2016, 03:14 PM
  4. Phife's First Build. Gantry CNC.
    By Phife in forum DIY CNC Router Table Machines
    Last Post: 01-21-2010, 08:19 PM
  5. Started build on CNC Mill. Lots of pics, sorry.
    By EvanZ in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2008, 02:24 PM
