Industrial laser equipment generates a lot of heat, which may damage the materials being processed and the laser components themselves. Therefore, industrial laser operators must ensure that their equipment is kept within the optimal temperature range by using relevant cooling equipment. https://monportlaser.com/collections/accessories
Operating CO2 laser at high temperature will reduce its accuracy and stability. Increased thermal stress can damage laser components, resulting in expensive maintenance or complete replacement of equipment. In addition, exposing sensitive materials to uncontrolled laser temperatures can change the manufacturing process, resulting in defects in the final product. Most industrial CO2 lasers can operate safely and effectively in the temperature range of 15°C to 25°C. https://monportlaser.com/collections...hiller-cw-5200
