586,121 active members*
3,592 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Combine standard gcode onto a fixture w/ 9 independent parts?
    Jan 2013
    52
    Arrow Combine standard gcode onto a fixture w/ 9 independent parts?
    I have a fixture assigned to g56, and that fixture engraves 9 individual plates at a time. Each with a unique design.
    Currently, to create toolpaths I import whatever 9 designs into the same folder (dxf). I then open my cam program (vetric cut2d), and import using one of their tools which atomatically spaces the dxf's out with the correct spacing according to my fixture. Each dxf file has the same size rectangle around the design to allow this behavior. I then select the appropriate geometry, create a toolpath, then export.
    Is there a better way I could be doing this? It seems like I should be able to generate gcode for each file individually and somehow combine them into a single file with offset instructions. I simply don't know what to search however. Can someone give me a lead?
    Thanks in advance for whatever insight you may be able to give!
    Jun 2015
    4154
    Re: Combine standard gcode onto a fixture w/ 9 independent parts?
    hy i can develop custom software
    if you wish, show your curent workflow, then what you wish to change, so to have a clue / kindly
    15362
    Quote Originally Posted by blitz355 View Post
    You can't get it easier than you are doing it, when you split it up into separate operations / programs you can use a different work offset for each part, you could also in Cut2D, just select one part at a time and have each part with a separate program, so once you lay it out, then just do each operation separate
    Mactec54
    It seems like I should be able to generate gcode for each file individually and somehow combine them into a single file with offset instructions.!
    easily done with a g52
  1. Gcode with 2 fixtures with pause in between fixture setup
    By ballistic42 in forum Autodesk CAM
    Last Post: 04-24-2019, 09:28 PM
  2. Is there a standard size for work-holding fixture hardware?
    By FoxCNC1 in forum DIY CNC Router Table Machines
    Last Post: 03-14-2015, 03:27 PM
  3. 3D standard parts a la TraceParts
    By Yeah! in forum Uncategorised CAD Discussion
    Last Post: 01-27-2010, 09:55 PM
  4. Combine then split then combine?
    By georgeburns in forum CNC Machine Related Electronics
    Last Post: 04-27-2008, 01:17 AM
