586,119 active members*
3,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP5000 program select method setting
    Mar 2007
    84
    Question OSP5000 program select method setting
    Hi everyone!
    So, a machine here is MC-4VA, system OSP5000M-G. Trying to load a program slightly bigger in size than buffer allows, and I got on screen this message: 2530 Program buffer owerflow ERROR 1. As far as I know there are different methods on how system read/load files -A, B, S, M. On AUTO mode screen, at the bottom there is a text: A-Mtd, so the system loads program directly to the buffer. What I have tried there is changing NC optional parameter (No.11) to 1 (setting for B-method), wait for 4min, switched off, wait for another 4min, switch system on. Still there is the same A-Mtd on AUTO screen, absolutely no change. Even if I try to enter for example PS TEST.MIN;B what I get is message 2156 option ERROR 'B' . I have done this both from BB1 and BB0 memory cards- all the same, only A-Mtd on screen. What is wrong there?
    Guntis
    Aug 2011
    419
    Re: OSP5000 program select method setting
    Check your management data card. I think you don't have B method program select option. This is specific(optional) function.
    If you want it, please PM me.
    "Imagination is more important than knowledge."
  1. pls, how to select method A B or S on lathe ?
    By deadlykitten in forum Okuma
    Last Post: 07-16-2023, 02:37 PM
  2. What's the best method for automatic depth setting?
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 10-10-2019, 02:17 AM
  3. Replies: 0
    Last Post: 06-22-2018, 10:51 AM
  4. Replies: 2
    Last Post: 06-11-2018, 05:31 AM
  5. Replies: 1
    Last Post: 01-10-2012, 09:50 AM
