586,112 active members*
2,999 visitors online*
    How to enable Remote / DNC mode?
    Hey guys!
    We've got a Spinner TC 42-MC lathe with a Fanuc 21i-TB control. The manual says the DNC mode is not active but we really want to run programs from memory card. In EDIT mode I can input or output programs from memory card but if I press the DNC button it really doesn't work. Any chance if it's possible to turn on this function? And how?
    Thank you for helping us.
    Dec 2009
    953
    Re: How to enable Remote / DNC mode?
    look at parameter 138 bit 7 to see if it is 1 (MDN)
    Quote Originally Posted by zavateandu View Post
    Thank you. I've checked and it was 0, but unfortunately nothing changed after I wrote it to 1. Any other idea?
    Dec 2009
    953
    if you can post the ladder file,i can help you
    i am sure it has something more to activate like a keeprelay or data table bit
    Try calling the program from the main memory. Have your program on your card (O1234 for an example). In memory mode run a program which calls the program on the card as a sub program. To do this you use M198 P1234
  1. Enable DNC Modify ladder Fanuc 0M
    By the_catalyst in forum Fanuc
    Last Post: 02-27-2022, 05:34 PM
  2. use Enable terminals with a toggle switch as a stand by mode
    By danbob5 in forum CNC "do-it-yourself"
    Last Post: 08-26-2021, 06:56 AM
  3. Fanuc 0i mf Always remote mode
    By rustam9622 in forum Fanuc
    Last Post: 04-16-2021, 03:03 PM
  4. DNC operation (REMOTE)
    By Castro in forum Fanuc
    Last Post: 11-16-2016, 07:23 PM
  5. Fanuc OM and Cimco DNC Remote Request
    By stang623 in forum Fanuc
    Last Post: 08-22-2011, 06:58 PM
