586,075 active members*
3,749 visitors online*
    Aug 2008
    12
    THC voltage variation
    I have observed that when I first start cutting material, the voltage present on the torch starts out very high. Eventually, it will “settle” to a value that I would expect the the material thickness and torch height. For example starting at 175V and eventually decreasing to 110V. I suspect that the work clamp circuit is exhibiting some kind of higher resistance that eventually reduces to something lower. I have been attempting to ensure the clamp make a good low resistance contact on the material being cut, but this phenomenon ALWAYS occurs for me. Has anyone else observed this type of voltage shift?
    Aug 2008
    12
    Talking Re: THC voltage variation
    I see I posted this in the wrong location. I will see if I can figure out how to move it or I will repost in a more appropriate
    location.
  1. THC Voltage Reading with a Non HF plasma
    By carlos_dr_7 in forum PlasmaCam
    Last Post: 12-10-2019, 10:09 PM
  2. plasma THC voltage
    By duraflap in forum Waterjet General Topics
    Last Post: 11-28-2016, 04:11 AM
  3. Voltage Dividers and THC
    By ajclay in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-21-2013, 11:20 PM
  4. Stand alone Arc Voltage THC
    By larryy1022 in forum News Announcements
    Last Post: 07-07-2010, 06:11 AM
  5. torch voltage and THC
    By stirling in forum Waterjet General Topics
    Last Post: 10-08-2009, 12:43 PM
